Thread started 26 May 2008 (Monday) 06:17
40d + Sport
mergino
Joined Jan 2005
May 26, 2008 06:17 |  #1
For fast moving sport is Aperture Priority, Al Servo & Central Focus Point the best combination to use on the camera?
Mike
ugly when I'm sober
Gallery: 51 photos
May 26, 2008 07:14 |  #2
It's a good start. I use M and set the shutter speed and aperture and adjust iso if needs be.
www.mikegreenphotograp​hy.co.uk (external link)
Gear
UK South Easterners
flickr (external link) Insta1 (external link) Insta2 (external link)
A closed mouth gathers no foot.
Mike ­ R
May 26, 2008 07:51 |  #3
As Mike said, I also suggest that you use M. That way you don't risk the shutter speed getting too slow in changing light. For example, at a night high school football game (US) the lighting is usually terrible but also changes form the 50yd line to the end zones. By using manual you can be sure that your aperture and shutter speed will not change. It's quick and easy to change your ISO. Same with a baseball game where each base can end up in a different light.
Mike R
www.mikerubinphoto.com (external link)
CanadianKitKat
May 26, 2008 09:35 |  #4
I always shoot in manual as well, but I do that for everything I shoot. Al Servo and centre point for tracking subjects.
www.ktklassen.com (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 26, 2008 10:45 |  #5
Or changing subject: How the subject affects the exposure & why manual keeps me worry free: Post #47
First set the f-stop & shutter speed you need. Then adjust the ISO. Need an exposure crutch?
Central Focus Point
If you can, try Custom Function C.Fn-13 (1) to put the focus points on the joystick (multi controller) which makes it easy to switch when things are moving fast.
AF Point selection for sports
xn2b8r
May 27, 2008 01:06 |  #6
If the light is even, I've had decent luck in AV and ISO 400, and bumping up the ISO when the light starts to fade. If you're shooting in RAW, I've found it's better to meter for the highlights. It's easier to add detail back into the shadowed areas in RAW post processing, but once the highlights are blown out, there's not much you can do for them.
--Jeff
1D Mark III :: 5D Classic w/BG-E4 :: EF 24-70 f/2.8L :: EF 135 f/2L :: EF-S 17-55 f/2.8 IS :: EF 70-200 f/2.8L IS II :: 580EX II (x4) :: ST-E2 :: Gitzo GT2330, GT1541T :: Markins M10 :: Feisol CF mono
bobbyz
May 27, 2008 15:18 |  #7
What I have seen is that even though your camera will say that highlights are blown out, there aren't blown out in reality and you can recover them unless you are way over-exposing. if I under-expose and adjust in pp, I get too much noise in shadow area.
I prefer manual exposure mode, AI servo and center AF point.
Fuji XT-1, 18-55mm
1,059 views & 0 likes for this thread, 7 members have posted to it.
40d + Sport
2794 guests, 157 members online
