Thread started 26 May 2008 (Monday) 06:57
How does opacity affect USM?
Rebecka
May 26, 2008 06:57 |  #1
For example, assume I applied a USM filter with a value of 50, radius of 50, and threshold of 0, on to a duplicate layer.
If I then reduced the opacity of that duplicate layers to 50% what would the effect be?
Would it be as if I had applied USM using the settings 25/50/0, or 25/25/0, is there a different formula, or would it be an effect that could not be created any other way?
Michael.
Comments, bribes, criticism, bribes, irrelevant anecdotes, and bribes always welcome.
EXIF is available inside all my photos, though bribes are still recommended anyway.
Damo77
May 26, 2008 17:20 |  #2
Reducing opacity would be closely equivalent to reducing the Amount, I'd say.
Damien
Website (external link) | Facebook (external link)
Rebecka
May 27, 2008 14:37 |  #3
That would be my instinctive thought too, but I am not certain and would like to understand what actually happens.
My reason for asking is from wondering whether it is okay to create an action that provides a high-ish level of USM for local contrast, then uses the opacity to set it to a suitable level for a particular photo.
Or would the results be too compromised that it would the only option is to manually apply USM on a photo-by-photo basis for local contrast.
Michael.
Damo77
May 27, 2008 17:19 |  #4
I'd say it's a viable option, as long as your images are all roughly the same size. Obviously the radius that works for a 12MP image won't work the same on a 3MP image.
If you were thinking of output sharpening (ie small radius) I'd be wary, because the Threshold would be too much of a factor; but for local contrast enhancement (ie large radius), where the threshold is usually kept very low for everything, it should be fine.
Damien
FlyingPhotog
Cream of the "Prop"
May 27, 2008 17:29 |  #5
You might also try "High Pass Sharpening..."
Duplicate your finished image on a new layer
Go to FILTERS -> OTHER -> HIGH PASS
Select a pixel width of between .5 and 1.0
Then go to layers and make that HIGH PASS treated layer either an OVERLAY or SOFT LIGHT (depending on how strong you want the sharpening effect)
Play with the opacity to see how it affects the sharpness of your photo
Jay
S.Horton
May 27, 2008 19:56 |  #6
Zoom to 100%, play with opacity, see for yourself.
You can also use the snapshot feature in history to save a few passes using different ideas, then flip back and forth to compare.
Sam - TF Says Ishmael
:cool:
carpenter
Gallery: 12 photos
May 27, 2008 21:34 |  #7
Just create 3 more layers. on the first copy layer apply your 50/50/0 and set to 50%. On the 2nd copied layer try your 25/25/0. On the top apply the 25/50/0. Then just toggle the top 2 layers on and off. Maybe over-exaggerate your sharpening a bit to see if there is a difference.
5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
Roach711
Joined May 2004
May 27, 2008 22:01 as a reply to  @ carpenter's post |  #8
I have a high pass sharpening action that deliberately sets the sharpening too high. I then reduce the opacity to get good sharpening without those nasty halos. I don't see why the same wouldn't work with USM sharpening.
50D, 100-400 L IS, 100 Macro 2.8, 24-105 L IS, 420EX, No talent
Shoot 'em all and let Photoshop sort them out.
René ­ Damkot
May 28, 2008 05:43 |  #9
If you go experimenting, don't forget to also experiment with the "blend if" sliders ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
freebird
May 28, 2008 09:57 as a reply to  @ René Damkot's post |  #10
I think you can use the "fade" command to do that can't you. If done next step after sharpening. Not sure , its been long time.
Examples I have seen were landscape images globally sharpened , even on the heavy side, then faded to taste. Seemed to work nicely for that.
Chuck
FlyingPhotog
Cream of the "Prop"
May 28, 2008 10:26 |  #11
freebird wrote in post #5611066 (external link)
Chuck
IIRC, that is a trick recommended by "Guru" Kelby as well...
And if it's good enough for him... ;)
Jay
Rebecka
Jun 01, 2008 06:07 |  #12
carpenter wrote in post #5608461 (external link)
I did just that, and all three gave different results.
Even adjusting the opacity level, in case it was not such a simple linear scale, I could not get it to match either of the other two. So it is clearly doing something different.
As it seems no one else has used this method I will have to find the time to try both approaches and see which comes up with the best results overall.
Michael.
2,157 views & 0 likes for this thread, 8 members have posted to it.
1043 guests, 105 members online
