I've suddenly become a metering moron.
Yesterday's shoot was horrible (outside location). I simply could not get a proper exposure using the Sekonic L-358. It's not the meter's fault, I must be doing something wrong. So, please tell me if I'm correct or not in my usage.
1. Dome extended, ambient light mode. Within that, I usually use the EV mode, but my results are just as bad with Shutter/Aperture Priority.
2. Place dome in front of subject facing camera.
3. Adjust aperture per meter reading.
4. Camera settings and meter settings match.
5. Look through viewfinder, 5D metering system says I am 2 stops on the dark side.
6. If I take the picture using the settings from the L-358 the histogram is mainly to the left.
7. If I open up the aperture by two stops, the histogram is more normal looking.
I'm having trouble knowing what to rely on, the L-358, the cameras metering system, or the histogram on the camera.
Before I discovered strobes/reflectors, etc., I normally used the camera's metering system for outdoor shots, and always adjusted the EV by 1 stop. Seemed to work, but I want to be as accurate as I can be, and get it right in the camera.
Last night I spent way too much time adjusting exposure, etc., when that all should have been correct at the time of the shoot.
I just spent the last two hours in my backyard working with the L-358 and my 5D, and came back in frustrated. Hence, the post.
Sorry, for being so long winded, but I need some help.
