My 5D has a 4 GB card. I take about 50 shots & it says CF Full and will accept no more photos. Move the card to the PC and I've only used about 1% of the space. What do I do/
bobbymc Hatchling 1 post Joined May 2008 More info | May 26, 2008 17:35 | #1 My 5D has a 4 GB card. I take about 50 shots & it says CF Full and will accept no more photos. Move the card to the PC and I've only used about 1% of the space. What do I do/
Tumeg Goldmember 1,823 posts Joined Nov 2007 Location: Orange County, California More info | May 26, 2008 17:39 | #2 Try formating your card via the camera's menu | Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
krusnof Senior Member 252 posts Joined Oct 2005 More info | May 26, 2008 17:40 | #3 Try a different card? Best regards
livinglight Member 35 posts Joined May 2008 More info | May 26, 2008 17:42 | #4 The most likely explanation is that you have moved photos to the Trash/Recycle Bin on the computer, but not emptied it. So they are still on the card. Josh Marshall
bsaber I have no idea what's going on 3,536 posts Likes: 3 Joined Aug 2007 Location: Los Angeles, CA More info | May 26, 2008 17:56 | #5 If it still persists after formatting in camera try doing a format on the computer.
PaulBradley Senior Member 278 posts Likes: 1 Joined May 2008 More info | May 26, 2008 18:05 | #6 You clearly have a special 40D that is producing 80MB RAW files. Interpolating from common file sizes that probably makes it somewhere between 60 and 80 megapixels. Perhaps there was a mix-up at the factor and they accidentally fitted the sensor that was supposed to go in this: http://www.itl.arizona.edu/Detectors/ITL_Detectors.htm
Coach Member 57 posts Joined Mar 2005 More info | May 26, 2008 19:07 | #7 Is it a matter of just needing to reset your camera's file number? As you approach 9999 the camera limits the available number of photos until resetting or starting a new folder.
photobitz PlatinumMeasurebaiter 6,501 posts Joined Jan 2006 Location: NSW, Australia More info | May 26, 2008 21:11 | #8 If none of the above works, I wonder if it is one of those counterfeit Sandisk cards? Dan
angryhampster "Got a thick monopod?" 3,860 posts Likes: 3 Joined May 2006 Location: Iowa More info | May 26, 2008 22:30 | #9 photobitz wrote in post #5601653 If none of the above works, I wonder if it is one of those counterfeit Sandisk cards?
Steve Lexa
| Latest registered member was a spammer, and banned as such! 2715 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
