Thread started 26 May 2008 (Monday) 20:17
I'm perplexed...why does this happen?
boomer3297
May 26, 2008 20:17 |  #1
Hi everyone,
Hope you can help. Why does the wrong person seem to be in focus in this picture...If zoom Browser is correct and I didn't re-compose why does this happen and what can I do in the future so this doesn't happen. Thanks for your help as usual.
Mike Attanasio
www.AttanasioImagery.c​om (external link)
JMHPhotography
May 26, 2008 20:21 |  #2
yikes.... if you did not recompose, either you stepped back or jerked back when you hit the shutter, or that lens is seriously front focusing. However... f/2.8 is not really ideal for taking photos of multiple people. Especially when you don't have them all on the same focal plane.
~John
(aka forkball)
Have a peek into my Gearbag. and My flickr (external link)
editing of my photos by permission only. Thanks
DStanic
May 26, 2008 20:30 |  #3
Perhaps the man in the middle was leaning forward when you composed the shot and he leaned back when you shot it? Aside from that it's either user error or your lens has a bad focusing problem (easiest problem to rule out).
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
Titus213
May 26, 2008 21:18 |  #4
Ah, the flaw in ZoomBrowser's ID of the focus point used. I would say you recomposed. Or hit the focus ring before shooting.
If you are using the shutter button to focus (haven't moved focus to the * button) the camera should not fire if it's out of focus and in normal single shot mode.
Dave
Perspiring photographer.
dave13
Joined Feb 2006
May 26, 2008 21:28 as a reply to  @ Titus213's post |  #5
How accurate are those settings? Were you really at f/2.8 at 1/30 shutter speed at 50mm?
As previously stated, 2.8 is too shallow of DOF and 1/30 is too slow for a 50mm focal length handheld.
JMHPhotography
May 27, 2008 10:52 |  #6
dave13 wrote in post #5601753 (external link)
I would have pointed out the shutter speed being to slow, but the fellow that is in focus is razor sharp so it's obvious that camera shake is not an issue with this image. I assumed he used a tripod or some other support, or has really steady hands. ;) The shutter speed/focal length relationship is more a guideline than a strict rule. Some people can hand hold a 50mm at 1/30 without issue, and some couldn't hand hold a 50mm at 1/90.... lol.
~John
(aka forkball)
boomer3297
May 27, 2008 19:37 |  #7
The exif data is straight from the camera and I believe I was in AV mode. 2.8 was used to eliminate the flash. Next, you say the SS is too slow but there is perfect focus on the wrong individual. I'm perplexed by that.
Mike Attanasio
boomer3297
May 27, 2008 19:40 |  #8
forkball wrote in post #5604908 (external link)
No tripod here, I have pretty steady hands......
Mike Attanasio
Jeff
May 27, 2008 20:32 as a reply to  @ boomer3297's post |  #9
If it happens quite often it's a problem with either the lens or body not being right. Otherwise it's probably just a missed-focus thing. It just happens occasionally, especially if the focus point is over a low contrast point.
I could see where the pattern in the shirt could be viewed as somewhat of a "texture" and the camera just didn't get it right. Same thing whent the focal point is on a cheek for example, no contrast, so it just misses. It happens.
Jeff
70D | Tokina 12-24 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: QHY268m, Astronomik Deepsky LRGBHaO3S2 filters, Meade 10" SCT, Astrotect 130EDT APO (.8x), iOptron CEM60 to keep it all off the ground.
MY AIRPLANE PICS (external link) | MY ASTRO PICS (external link)
Titus213
May 27, 2008 20:40 |  #10
jseivert wrote in post #5608111 (external link)
In a camera set up to focus and meter with the shutter button would the camera fire if it didn't achieve focus on the selected focus point?
Dave
Jeff
May 27, 2008 20:47 as a reply to  @ Titus213's post |  #11
No, if you see the little blinking light in the viewfinder it won't fire. (Assuming AF mode is set on the lens)
Edit: But since the red square lit up, the camera thinks it has focused correctly.
Jeff
iamaelephant
May 27, 2008 21:29 |  #12
The 50 f/1.8 is pretty notorious for misfocus. It's possible that it misfocused and the guy in front just happened to be sitting the in focal plane it took.
-- Martin
Canon 30D | Tamron 17-50mm f/2.8 | EF 50mm f/1.8 II
Titus213
May 28, 2008 00:18 |  #13
What I'm getting at is that I think ZoomBrowser is simply showing you what AF point was active when the image was taken. It doesn't show you where that AF point was when focus was achieved.
Add this to the fact that unless focus was achieved (on something) the camera wouldn't take the picture.
Now we have a probable case of focus and recompose.
Dave
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
May 28, 2008 01:35 |  #14
If you focused on the center AF point, did not focus and recompose and their was no movement/change in position by the subject or the shooter, then I'd say it's front focusing.
If this is always occurring then you have an issue and may want the lens calibrated.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Jeff
May 28, 2008 12:53 as a reply to  @ Tee Why's post |  #15
Hey Boomer, can you let us know if this is a rare deal or if it's a constant problem?
Jeff
2,005 views & 0 likes for this thread, 10 members have posted to it.
2575 guests, 162 members online
