Does anyone have a web site to compare the 1.6X crop camera to full frame cameras lens comparison.
Thank you..
BLEITH1965 Senior Member 465 posts Likes: 7 Joined Feb 2007 More info | May 26, 2008 21:11 | #1 Does anyone have a web site to compare the 1.6X crop camera to full frame cameras lens comparison.
TopGear1Ds Senior Member 600 posts Joined Nov 2007 Location: Silver Spring, MD, USA More info | May 26, 2008 21:17 | #2 |
Hi, what I'm trying to find out is the lens difference using a crop camera 1.6X compared to using a full frame 35mm camera.
TopGear1Ds Senior Member 600 posts Joined Nov 2007 Location: Silver Spring, MD, USA More info | May 26, 2008 21:28 | #4 do you mean which lenses you can use on each type of camera, or how the field of view changes between the two types of bodies? Sorry for not understanding.. --Matt--
weka2000 Is that a 300mm in your pocket? More info | May 26, 2008 21:31 | #5 BLEITH1965 wrote in post #5601739 Hi, what I'm trying to find out is the lens difference using a crop camera 1.6X compared to using a full frame 35mm camera. On 1.6 crop the corners are sharper, you can get away with cheaper lens. Also there is a DOF difference.
What is the DOF difference. That's got to be my question is there a chart that compares the two? Thanks..
CanonSoldier ..."kind of like Zooms"? 803 posts Joined Mar 2008 Location: Arrested with no pants in the nuthouse More info | May 26, 2008 21:50 | #7 its not that complicated. You will get better image quality over all with the full frame cameras, but with the 1.6x you can get away with cheaper lenses because you might not need the longer ones. The DOF difference has to do with the 1.6x of the focal length. A 50mm 1.2L lens will have a certain amount of DOF, but when you put that lens on a 1.6x, it becomes a 76mm f1.2L lens, which will have less DOF due to the increased focal length. Na, just kidding, you are still a loser.
runninmann what the heck do I know? More info | May 26, 2008 21:57 | #8 Canon Soldier wrote in post #5601889 its not that complicated. You will get better image quality over all with the full frame cameras, but with the 1.6x you can get away with cheaper lenses because you might not need the longer ones. The DOF difference has to do with the 1.6x of the focal length. A 50mm 1.2L lens will have a certain amount of DOF, but when you put that lens on a 1.6x, it becomes a 76mm f1.2L lens, which will have less DOF due to the increased focal length. Are you saying that a given FL lens at a given aperture will produce less DOF than the same lens on a FF camera?
TopGear1Ds Senior Member 600 posts Joined Nov 2007 Location: Silver Spring, MD, USA More info | May 26, 2008 22:02 | #9 It sounds weird, but its true if this DOF calculator --Matt--
Calzinger Goldmember 1,798 posts Joined Jan 2006 Location: New York More info | May 26, 2008 22:14 | #10 Canon Soldier wrote in post #5601889 The DOF difference has to do with the 1.6x of the focal length. A 50mm 1.2L lens will have a certain amount of DOF, but when you put that lens on a 1.6x, it becomes a 76mm f1.2L lens, which will have less DOF due to the increased focal length. Completely incorrect. "That building in the background is distracting."
TopGear1Ds Senior Member 600 posts Joined Nov 2007 Location: Silver Spring, MD, USA More info | May 26, 2008 22:22 | #11 Calzinger wrote in post #5602030 it's quite the contrary to your claim, crop bodies typically have more DOF. Yes and no. Its true that if you move closer in order to get the same FOV that the FF will have less DOF. --Matt--
Calzinger Goldmember 1,798 posts Joined Jan 2006 Location: New York More info | May 26, 2008 23:03 | #12 TopGear1Ds wrote in post #5602099 Yes and no. Its true that if you move closer in order to get the same FOV that the FF will have less DOF. BUT, the same lens at the same distance on a 1.6 crop and FF camera will give more DOF on the FF. I guess its just apples and oranges at that point though, because like you said, you're now dealing with two different FOV's so your image wouldn't be the same. What's the point in comparing two images of different FOVs? The question was regarding DOF, and in everyday shooting, the FF will typically have less DOF. I would think that you would frame your shot similarly regardless of format. That's why I used the word typically, as in everyday shooting. "That building in the background is distracting."
TopGear1Ds Senior Member 600 posts Joined Nov 2007 Location: Silver Spring, MD, USA More info | May 26, 2008 23:07 | #13 I wasn't disagreeing with you. You quoted my post, but did you read it? --Matt--
penagate Senior Member 389 posts Joined Jan 2007 Location: Sunny Adelaide More info | May 26, 2008 23:29 | #14 In theoretical terms, when all other variables are equal — focal length, shooting distance, size of print, viewing distance — the APS-C image has a greater amount of magnification, therefore it has a shorter depth of field than the 35mm-format image. 5D, 400D
liquefied Goldmember 1,160 posts Joined Oct 2006 More info | May 26, 2008 23:34 | #15 FF will have shallower depth of field than 1.6x at a given FoV, not focal length. DoF remains the same whether it's 50mm f/2 on a 1.6x or on FF. What changes it the field of view so that the 50mm lens would give a FoV of an 80mm lens when used on a 1.6x but still have the DoF of a 50mm lens.
| Latest registered member is ealarcon 705 guests, 132 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
