You don't need a fisheye to shoot good skate stuff. If you're going to shoot long lens though, you don't have to get super-tight comp. Try to get some of the surrounding area in it while still lighting the skater well. Here's an example I did just two days ago.
| Byte size: ZERO | Content warning: NOT AN IMAGE |
There are a thousand things I don't like about this photo (especially the blown out ground) but you can get the gist of it. Even when shooting quarterpipe-style obstacles, don't give up on landscape. You can get some really col shots that way.
Also, when you do decide to purchase a fisheye, you will learn that the viewfinder is not a necessary tool... one can quickly pull away a camera right after the pic is taken so that the subject can land the trick. Like this!
As far as dead center goes, just get your weighting right before even taking the shot! But you are off to a good start, I look forward to seeing your new stuff.
