. . . between the large softbox included in the Elinchrom D-Lite 4 kit and the Lastolite Umbrella Box.
Build Quality
Neither can brag too much on build quality, but the Elinchrom boxes are superior (in the way that a 1981 Chevy Cavalier is "superior" to a 1979 Yugo). When the Lastolite bag is opened, the smell of dime store beach ball hits you, and it feels and looks cheap as well. The second time I opened the umbrella, one of the tips came off. I was able to put it back on, but it will never be on securely.
Ease of Use
The Lastolite hands down. The Elinchrom boxes are a strain to put together. I used curse words I didn't even know I knew putting the boxes together. If you can use an Umbrella, you can use the Lastolites (if you can't use an umbrella, you probably shouldn't have photography as a hobby!). You do have to pull the white diffuser towards the head of the D-Lite and then zip it around the light which can be a bit tricky, but nothing like putting those @%#**% boxes together! Also, when you put the umbrella shaft through the head, you have to force it a bit more than you might be comfortable doing.
Results
I tried to control the test as much as possible. Both shots were taken with the same exposure (/4.5@1/200 (INVALID EMAIL), ISO 100) and at the same distance. Both the model (my daughter) and I thought that the light was much brighter with the umbrella, but they metered out the same. The only PP'ing I did was a bit of healing stamp and a bit of a crop. That's it.
This is with the Elinchrom softbox:
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
This is with the Lastolite Umbrella box:
For some reason, the Elinchrom is a much warmer tone which I find more pleasing. I do like the catchlights of the umbrella better though (if I can think of it, I'll post a larger crop). I can warm the umbrella shot up in Photoshop. All in all I'd call it a push. The umbrellas are $67 at B&H, and I bought them for location use and larger group shots. Hope they do OK for that!
