can anyone recommend a light sturdy tripod for hiking? it will hold a 40d, possibly gripped with a 24-105.
azpix Goldmember 3,335 posts Likes: 19 Joined Oct 2006 Location: Chandler, Arizona USA More info | May 28, 2008 00:45 | #1 can anyone recommend a light sturdy tripod for hiking? it will hold a 40d, possibly gripped with a 24-105. Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
azpix THREAD STARTER Goldmember 3,335 posts Likes: 19 Joined Oct 2006 Location: Chandler, Arizona USA More info | May 28, 2008 01:56 | #2 right now i have a bogen 3021b pro with 488rc2 head. the tripod weighs about 1 lb and the head is just over 2lbs. Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
johnz Senior Member 529 posts Joined Sep 2006 Location: Tampere, Finland More info | May 28, 2008 03:35 | #3 I have a feisol cf tripod, and i mostly use it with manfrottos quite heavy camerahead, but when i take it outside i switch to the ball head that came with it. It's a very small and compact ballhead with QR-plate, made by Feisol. It's not a very good ball head in general, but it does the job when i am outside and it's very light and compact. - Tuomas Gustafsson
LesterWareham Moderator More info | May 28, 2008 06:37 | #4 azpix wrote in post #5609327 can anyone recommend a light sturdy tripod for hiking? it will hold a 40d, possibly gripped with a 24-105. As a light weight pod I use a Velbon CF 530 Pro Tripod (carbon fibre), Velbon PH-253 ball and socket head + a smaller Kirk AS QR, very light weight about 1.1Kg all up, comes with carry bag, stone bag, weight hook. Centre column splits for low level use and legs can be set to different angles. Great for light weight stuff where you can use MLU like flowers closeup and landscape, it is even OK with a 400mm lens as long as you use MLU and the wind is not too high. Gear List
JimG I feel thoroughly satisfied 12,255 posts Likes: 2 Joined Jun 2005 Location: Australia. More info | May 28, 2008 06:43 | #5 I use a Feisol CT-3442 for hiking and I would highly recommend it. At 1,050 grams and <19" folded including head (so long as you don't have a massive head) it's perfect for this application. Gear Listhttp://www.codastudios.com.au
jhom Goldmember 1,320 posts Joined Apr 2007 Location: Dallas, TX More info | May 28, 2008 07:40 | #6 I would recommend a Gitzo 0 or 1 series tripod with a Markins Q3 ballhead. Jim
Shuko Senior Member 377 posts Joined May 2008 Location: Finland More info | May 28, 2008 10:00 | #7 Here is my Feisol CT-3442 with Markins Q3 (48cm/19in and 1430g/3.15lb)
I have been reading all the tripod threads and trying to make a decision. I just weighed my 5D w/24-70 at 4.47 lbs, 5D w/70-200 2.8 IS is 5.12 lbs the 40D with 300 F-4 is 5.01 lbs. These were without grips. I'm going to go with Markins Q3 and 0530.
edrader "I am not the final word" More info | May 28, 2008 10:50 | #9 azpix wrote in post #5609494 right now i have a bogen 3021b pro with 488rc2 head. the tripod weighs about 1 lb and the head is just over 2lbs. trying to get the weight down. Is there a lighter weight head I can use on this tripod? it's gotta weigh more than that http://instagram.com/edraderphotography/
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | May 28, 2008 11:19 | #10 Win wrote in post #5611279 I have been reading all the tripod threads and trying to make a decision. I just weighed my 5D w/24-70 at 4.47 lbs, 5D w/70-200 2.8 IS is 5.12 lbs the 40D with 300 F-4 is 5.01 lbs. These were without grips. I'm going to go with Markins Q3 and 0530. 530? "I think the idea of art kills creativity" - Douglas Adams
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | May 28, 2008 11:41 | #11 I know a few on here know I have the 0530/Q3 and will say that it works fine with the 40D & 70-200 f/4L with a tripod collar on the lens. Even extended I haven't seen an issue and detail in photos has been very sharp to my liking and I'm picky about that.
In real life the 530 will be paired with either a 17-40 or 24-70. I hardly ever hike with a longer lens. I have a 3221 and that's in the car if I need it. The 1530 does have a height advantage which may still sway me that way.
azpix THREAD STARTER Goldmember 3,335 posts Likes: 19 Joined Oct 2006 Location: Chandler, Arizona USA More info | May 29, 2008 01:28 | #13 you're right, don't know what i was thinking. My pod is 5 lbs and head is about 2( taken from specs oniline) Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | If you don't want to spring for a Gitzo, give a look at the Velbon El Carmagne series (similar to what Lester posted). Prior to getting a Gitzo, I was using a Velbon 540 carbon fiber, with a Gitzo 1277M ballhead and an RRS lever clamp. It weighs much less than your current set-up, and handled my gear without any problems. The Velbon is a good, middle-of-the-road package. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
azpix THREAD STARTER Goldmember 3,335 posts Likes: 19 Joined Oct 2006 Location: Chandler, Arizona USA More info | May 29, 2008 10:30 | #15 argyle wrote in post #5616919 If you don't want to spring for a Gitzo, give a look at the Velbon El Carmagne series (similar to what Lester posted). Prior to getting a Gitzo, I was using a Velbon 540 carbon fiber, with a Gitzo 1277M ballhead and an RRS lever clamp. It weighs much less than your current set-up, and handled my gear without any problems. The Velbon is a good, middle-of-the-road package. But if you can spring for a Gitzo 0 or 1 series with the Markins Q3, you surely won't be disappointed...the minute you pick one up in your hands, you will feel how well they're built. I gave my GT2540 some pretty rough treatment out at Havasu Canyon over four days...in water, crawling through tunnels, climbing down cliff faces, dirt/dust and bushwhacking, and it worked flawlessly. Unless something better comes along, I'll probably continue to stick with the Gitzo line...a bit more expensive than others, but you get what you pay for.
| Latest registered member was a spammer, and banned as such! 2854 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
