I am looking to buy a cheap macro set up for my recently ordered 100 f2.8 macro, will this older ringlight fit my lens? Is it worth having? thanks
birdfromboat Goldmember 1,839 posts Likes: 1 Joined Mar 2008 Location: somewhere in Oregon trying to keep this laptop dry More info | May 28, 2008 13:31 | #1 I am looking to buy a cheap macro set up for my recently ordered 100 f2.8 macro, will this older ringlight fit my lens? Is it worth having? thanks 5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
Marbeck Senior Member 606 posts Joined Dec 2005 Location: Bridlington,UK More info | May 28, 2008 17:01 | #2 I have this same set up and it works ok. Yes it does fit the 100mm macro. The problem is it is too strong in my opinion. You don't have flash exposure compensation with this flash. I had to put some black tape over half of the flash lenses, then us a fast sutter with a narrow apature. Remember that the max speed on the shutter for the flash will only be 200-250.I got some good results around F/22 and sutter speed at 1/250 sec . You may be able to lower the output with some masking tape over the lenses on the flash as well. Like I said it works but not as nice as the newer set ups. Martin Birkbeck :Canon EOS 6D(Gripped)
birdfromboat THREAD STARTER Goldmember 1,839 posts Likes: 1 Joined Mar 2008 Location: somewhere in Oregon trying to keep this laptop dry More info | thanks for the good info. I went ahead and ordered the thing, should get here about the same time as my new lens. I am a total flash newbie, always worked around the stuff if possible, a holdover from film days and bad experiences. I am going to learn alot with this lens and ringlight, maybe someday I will get the fancy one, but not till I know why I need it. thanks again. 5D, 10D, G10, the required 100 macro, 24-70, 70-200 f/2.8, 300 f2.8)
| Latest registered member was a spammer, and banned as such! 2816 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
