Thread started 28 May 2008 (Wednesday) 16:43
Circular Polarizer - Arrived
Shasta
May 28, 2008 16:43 |  #1
Ok I feel really stupid asking this question. I just purchased a circular polarizer but I'm curious why does the filter spin? I would think a gradient filter to spin but what is the reason behind this feature.
Thank you.
Freff
May 28, 2008 17:03 |  #2
"Just turn its front part to adjust the effect and watch it appear in the viewfinder.
Remember that the effect is stronger when you have the sun at 90° on your left or right. It will be less visible with the sun in your back and almost non-existant with the sun in front."
http://www.offrench.ne​t …les/polarizing_​filter.php (external link)
Tony
"I would give my right arm to be ambidextrous"
"I used to be indecisive, but I'm not so sure anymore"
Jon
Joined Jun 2004
May 28, 2008 20:03 |  #3
Polarized glass is directional. It stops light vibrating at one direction, while allowing light vibrating at right angles to that to pass. Since you don't always know which direction you want the light to be vibrating, you need to spin it. Point it at a subject and watch as you rotate the filter.
Jon
Cocker Spaniels
FLY ­ GTI
May 29, 2008 10:14 |  #4
Look through the view finder at the sky and spin it.
argyle
May 29, 2008 11:25 as a reply to  @ FLY GTI's post |  #5
Since its obvious by your post that you've never used one before, here's a tip: when looking through the viewfinder, be sure to rotate the filter in the CCW direction...there's less of a chance for you to accidentally unscrew it and have it fall to the ground.
Shasta
May 30, 2008 21:29 |  #6
Thanks for the tips. Appreciate everyones help, never knew they worked that way.
SoaringUSAEagle
Daddy Of The Crop
May 31, 2008 01:36 |  #7
argyle wrote in post #5618467 (external link)
I spin mine this way as well, just to be safe.
5D4 | 50 1.4 | 85L II | 24-70L II | 70-200 2.8L IS II
Ben ­ Daniels
May 31, 2008 10:43 |  #8
You can look a right twat when spinning the filter the wrong way, and it falling to the ground.
Ben
" All the gear, but no clue!"
5DMK2 w/Grip: 40D w/Grip: Canon D60: 100mm F2.8 Macro USM : EF17-35mm F2.8
L : EF70-200mm f4L IS : Canon 1.4x Converter II : BG-E2 grip :TC420EX : Tamrac Ex5 bag :Manfrotto 055XPROB:Lee Filter System
1,256 views & 0 likes for this thread, 7 members have posted to it.
2531 guests, 170 members online
