Thread started 29 May 2008 (Thursday) 09:00
Measure Battery Remaining Capacity
Maxdave
Gallery: 49 photos
May 29, 2008 09:00 |  #1
I have a multimeter and would like some advice on using it to measure the remaining life in a 40D or a XTi Li-ON battery. What should I measure? I presume I need a voltage reading.
I can fully charge a battery to get a baseline so to speak, but does anyone have advice on what I should look for in a measurement to determine the amount of charge remaining after a period use or storage?
Thanks!
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
rdc640
May 29, 2008 09:08 |  #2
fully charge them, measure voltage
wait til its run out, then measure voltage again?
so you know voltage at full and voltage at empty, will be able to hazard a guess at whats left in them no?
PaulBradley
May 29, 2008 09:36 |  #3
Yeah, there will be a voltage drop as the battery depletes. I doubt it's linear, but it's probably enough to get a rough idea of remaining capacity.
Jon
Joined Jun 2004
May 29, 2008 10:21 |  #4
Don't forget that you need to take that measurement under some kind of load.
Jon
Cocker Spaniels
JohnJ80
May 29, 2008 21:32 |  #5
With Li-ion batteries it doesn't work well. Li ion batteries hold their voltage up very close to the top until they are almost depleted, then the voltage crashes. You need to basically watch the current usage and sum it up against the known battery capacity to be accurate. There are fuel gauge chips that do that for you but you will not be very happy with the results from a volt meter. It is the same problem with the gauge on the camera - shows full until it a few frames later it starts to drop rapidly.
Li Ion batteries do not self dishcharge fast so you can charge them up as soon as you are done using them and they will be ready to go even if they sit for a long time.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
2,016 views & 0 likes for this thread, 5 members have posted to it.
1040 guests, 106 members online
