Thread started 29 May 2008 (Thursday) 16:13
Hazy Landscapes
rogue1208
May 29, 2008 16:13 |  #1
Hello All,
I am a noob with a Rebel XTi who has just discovered this site :). I tried my luck with shooting a few landscapes, and was a little disappointed with the quality of the shots - the short of it is that the shots come out hazy and unimpressive.
First, a few specs. I have an f1.8 50mm EF-S lens mounted on my XTi body, with no filters, etc. I almost always shoot on Av, and for a lot of the aforementioned shots I had the lens pretty wide open. Since these shots were taken around noon, I didn't have to venture past ISO 100. The images were captured as large JPEGs. No other 'tweaking' was done for the shots (white-balance, exposure compensation, etc., mostly because I have no clue what they actually do :P).
Now when I looked at the scene with the naked eye, it was inspiring and clear, with lots of vivid colors and textures. My shots, however, are a different story. They look like someone has smeared a bit of gray film over the picture. I have heard that maybe a UV or haze filter will help, but I am not really sure if this is the answer. Any tips would be greatly appreciated.
Thanks!!
exile
Joined Nov 2005
Location: UK (South West...now East Anglia ...and back in Northern Ireland at last)
May 29, 2008 16:21 |  #2
Can you post some pics for us to see please?
Outdoor photographer and writer in Northern Ireland (external link)
http://www.flickr.com/​photos/80146277@N00/ (external link)
TheHoff
Don't Hassle....
May 29, 2008 16:25 |  #3
First, noon is the worst time to shoot anything outdoors, landscapes included. Next, the haze can be removed with your processing software -- what are you using? It can be done with "curves" or with USM.
••Vancouver Wedding Photographer  (external link)••| [gear list] | Latest blog: 5 steps to stopping image loss (external link)
Molnies
May 29, 2008 16:27 |  #4
rogue1208 wrote in post #5620462 (external link)
First of all, do you mean the EF-S 18-55 lens or the EF 50 f/1.8?
Second, shooting outdoors at noon should not be needing an aperture of 1.8 or around there. Landscape if often shot with an aperture of around 5.6-11 depending on lens and light... So something is wrong right there. Also, don't be afraid to go past ISO 100 on the XTi, it should be able to handle ISOs up to around 800 without any problems.
Fredrik — Portfolio (external link)
50D — 350D + BG-E3 — 100-400mm L IS — 100mm f/2.8 Macro — 50mm f/1.8 — EF-S 18-55mm — Tamron 90 f/2.8 Macro
Manfrotto 055ProB + 488RC2 — Speedlite 430EX — Sigma EM-140 DG Macro flash — Kenko tubes
rogue1208
May 29, 2008 19:49 |  #5
Thanks for the replies!
exile (and everyone else) - here is a sample shot:
HTTP response: 404 | Byte size: ZERO
The entire album can be found at http://picasaweb.googl​e.com …1208/MalibuCree​kStatePark (external link). There are a couple that came out OK (the closeups with the branches, etc.), but in general pretty disappointing.
Molnies - I am using the EF 50 prime lens, not the 18-55. And when I said I had the lens pretty wide open, I actually couldn't do 1.8. The shutter speed doesn't go faster than 1/4000, and the shots would have been overexposed. I will keep in mind your suggestion w.r.t ISO.
TheHoff - I will try the shots at daytime or at dusk. Maybe an overcast day would help? I did have a few shots in London that came out better - they aren't landscapes per se, but they do look nice. Here is one of my favorites:
I use GIMP for post-processing. I tried mucking with the curves a little bit, as well as USM. However, I am not sure how to use them properly.
NMGolfHacker
May 29, 2008 19:57 |  #6
That LA...it is called smog. :)
Gripped Canon XTI - Sigma 18-50 f/2.8 Macro, EF-S 55-250IS, Nifty Fifty, Speedlight 420ex
rogue1208
May 29, 2008 20:00 |  #7
ack - not sure if the images showed up or not. I have attached them just in case. The first one is the really hazy landscape, and the second is the London shot that I mentioned. I think they were too big (7 MB or so) to begin with.
TheHoff
Don't Hassle....
May 29, 2008 20:02 |  #8
Yea I had a look at the hazy landscapes... as was said, that is smog, or general pollution. Since it is only in the background (or at least you're shooting through more of it) it was tough to get rid of quickly since using adjustments gave the foreground too much contrast. Best bet is to look for a better day and time of day.
chauncey
May 29, 2008 20:05 as a reply to  @ NMGolfHacker's post |  #9
Smog or no, ya still got to take advantagr of those evening and morning magic hours.
rogue1208
May 29, 2008 20:17 |  #10
I will try different times of day, and clearer days as well. Thanks a lot everyone!!
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 29, 2008 20:42 |  #11
How the subject affects the exposure & why manual keeps me worry free:
Post #47
First set the f-stop & shutter speed you need. Then adjust the ISO.
Need an exposure crutch?
829 views & 0 likes for this thread, 7 members have posted to it.
Hazy Landscapes
2753 guests, 161 members online
