Thread started 29 May 2008 (Thursday) 21:41
Glare on my filter
GyverX
1 post
May 29, 2008 21:41 |  #1
I was taking some shots of my wife while she was doing karaoke and this place has LOADS of lights. Checking out my shots, I find that I am getting A LOT of reflection and glare on my filter/lens. Things like the TVs that display the words and most of the colored lights.
I was using a nifty fity on my rebel XT, all in raw format.
The nifty-fity has a Opteka HD II UV filter. Most of the shots are done at 1.8 becuase even though there were a lot of lights, it was still pretty dark.
Is there a filter that will stop this glare or am I stuck with this and just use a ttl flash?
Thanks for any help
GyverX.blogspot.com
eddarr
There's Moderators under there....
May 30, 2008 00:14 |  #2
Welcome to the forum.
Bar and nightclub shoots can produce flare. Look in the performing arts forum at photos, it is quite common.
Loose the opteka filter. This can make the flare more pronounced.
Eric
iamaelephant
May 30, 2008 00:32 |  #3
Lose the filter. This should seem pretty self evident.
-- Martin
Canon 30D | Tamron 17-50mm f/2.8 | EF 50mm f/1.8 II
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
May 30, 2008 01:04 |  #4
You can get a top of the line multicoated UV filter that costs almost as much as the nifty fifty and minimize flare from having a filter or go without filter if you really want to minimize flares from strong lights.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Glenn ­ NK
May 30, 2008 01:10 |  #5
GyverX wrote in post #5622305 (external link)
Thanks for any help
Lots of lights? Are you using a lenshood? All the time? If not, do it, and then please let us know the results.
When did voluptuous become voluminous?
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
May 30, 2008 10:01 |  #6
Good question.
Another option is to learn to use the flare to add interest to the images. See the last one here:
The Johnny Headband Band
Cody21
May 30, 2008 10:10 |  #7
This topic begs the question (not meaning to hijack this thread). I bought a UV filter as a "protector" for my expensive lenes. Do you people attach & remove your "filter" for specific shots? (e.g., landscape, indoor bright ligts, etc.) It's sounding like you do (ala the OP's issue). I've always just left mine on and wondering if "tack sharpness" of certain shots could be improved.
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
Glenn ­ NK
May 30, 2008 12:52 |  #8
Cody21 wrote in post #5625027 (external link)
As you likely know, this question/debate recurs at semi-regular intervals; there are those that always use them, those that never use them, and of course some that fall in between, taking them off in "dangerous" situations.
It is likely that if one uses an absolute top quality UV filter, that few problems will be encountered; there are situations where problems of flare will arise.
I seldom shoot directly into the sun, and if I do (sunset at early stages), then there will likely be lens flare in any event, and the filter may not contribute significantly to the effect.
I've always used a hood, and been aware that if light (particularly sunlight) falls directly on the front of the lens, then trouble will appear. If the hood isn't long enough, I frequently use my hand or a cap to shield the lens - this not always being possible (very shallow angles between sun and axis of sight).
Any dust on a lens or filter will magnify the problems if light falls on these elements - keep them spotless.
There are those that believe that any additional glass in front of the lens degrades the image quality - technically I would agree - but from a practical point, I'm not worried about it.
The Canon 24/105 zoom lens has 13 glass elements (the 17/55 has 19) - adding one more high quality piece of coated optical glass doesn't seem to me to be terribly significant - to some people it does - everyone does what one believes in.
As for "tack sharpness" issue, I suspect that if one did strictly controlled tests (and light on the front of the lens was eliminated), one couldn't tell the difference. It's far more likely that variables such as lens quality, the type of PP done, shutter speeds, f/stop, ISO, etc. would have more effect than a high quality filter.
René ­ Damkot
May 30, 2008 13:15 |  #9
Oh no, it doesn't...
Not again :p
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
yogestee
May 31, 2008 08:38 |  #10
Nope.. I leave mine on..
Jurgen
SkipD
Joined Dec 2002
May 31, 2008 08:48 |  #11
I don't even own a filter for "protection" and have never in more than four decades found a real need for one. However, I usually don't take my camera out into blowing sand or rain or similar hazardous (for the camera) conditions.
Skip Douglas
1,002 views & 0 likes for this thread, 10 members have posted to it.
Glare on my filter
2830 guests, 162 members online
