John E wrote in post #5625366
Thanks guys. I think that one of the reasons my CS3 is running so slow on my Pentium M laptop is that I have a ton of plug-ins and actions. It takes about a minute just to boot up. I should probably delete all that I don't use.
Dell is somewhat deceptive. They sell you 4 gigs of Ram even though you can only use three. This is what I heard anyway. They don't even suggest that you have too much ram to be used by the system.
Thanks for letting me know that I could install vista 64 on the new quad core machine. I'm almost afraid to try it at this point. I'll see how the 32-bit version works first. Nowhere on Dell's website does it even mention 64-bit windows - at least I couldn't find it anywhere.
Everything from Intel Core 2 Duo and newer has 64-bit support. Even some chips older than that are compatible.
The important thing to check is that you will need 64-bit drivers for all of your hardware and perpiherals. You can run 32-bit programs, but all drivers must be 64-bit.
The issue with them selling you 4GB of RAM vs. 3GB of RAM is somewhat moot. The problems with 32-bit OS is that depending on a lot of different factors you could end up able to access anywhere from 3GB to 3.6GB or so. Even with 64-bit systems, if your motherbaord doesn't support memory remapping, you won't use all of the RAM in the system. It's quite confusing even to someone with decent knowledge of systems, so they probably just let you buy 4GB and limit it to that since you technically can use over 3GB. Anything more than 4GB would be a waste with a 32-bit system, but having 4GB is fine. Also you have to take into account the graphics card and that it can appropriate memory for its own use, which complicates things - shared memory for the video card can introduce the situations where you can use more than 3GB on a 32-bit system, but just that some is used for video and you won't be able to really tell.
If you decide to upgrade to 64-bit Vista, I believe you can get a discount or a free CD....not sure if that offer is still going on - you would have to contact Microsoft.
