Does anyone know if the 20D battery grip is compatible to work with the 40D?
Photoman65 Senior Member 303 posts Joined Nov 2006 Location: Dallas, TX More info | May 30, 2008 23:58 | #1 Does anyone know if the 20D battery grip is compatible to work with the 40D? Canon USA Gear! Cameras: 5D MKIII & 7D L Lenses: 24mm-70mm f/2.8, 85mm f/1.2 II, 70mm-200mm f/2.8 IS, 1.4II Ext, 580 EXII Speedlite
HuskyKMA "Now what?" 1,749 posts Likes: 1 Joined Feb 2008 Location: Castle Rock, WA More info | May 31, 2008 00:23 | #2 Yep, the BG-E2 sure is. Canon 40D w/ BG-E2N Grip| 400mm f/5.6L | 70-200mm f/2.8L IS II | 28-135mm f/3.5-5.6 IS | 10-22mm f/3.5-4.5 | Gitzo GT3541LS w/ RRS BH-55
tplyons Member 92 posts Joined Apr 2007 Location: Easton, PA More info | IIRC the only difference is with the BG-E2N is the o-ring seal. -Timothy Patrick Lyons
May 31, 2008 00:52 | #4 Awesome! This is good to know because I don't have to buy a new batter grip if I bought the 40D. Canon USA Gear! Cameras: 5D MKIII & 7D L Lenses: 24mm-70mm f/2.8, 85mm f/1.2 II, 70mm-200mm f/2.8 IS, 1.4II Ext, 580 EXII Speedlite
| Latest registered member is josetide 1046 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
