Vendee wrote in post #5631879
Thanks to everyone who replied. Rankinia, yes I know the Z system would be better with my 10-22 but its so much more expensive. I will be buying the "wide" single slot P filter holder and from reading old threads here, I'll only get a bit of vignetting at 10mm and I can live with that.
As for the Cokin ND grads, or lack of them, I'll probabaly go with Hitech ND grads although I'm a bit worried after reading that the Hitech 85mm filters are sometimes a very tight fit in the Cokin holders
If you can swing it, though, you may want to go with the Cokin Z-Pro or the Lee holder. If you plan on doing a lot of landscape shooting, you will at some point in time come across the need to stack GND filters...the Cokin P wide angle holder won't let you do this since it only has a single slot. Really, if you're able, give some thought to the either of the larger holders. Its a few dollars more, but in the end, its cheaper to get it now than afterwards.
