Thread started 31 May 2008 (Saturday) 11:51
why are my flashed pictures coming out like this?
Blender7
May 31, 2008 11:51 |  #1
Hey all,
I have a problem with my flash. I have a 420ex and a 30d combo. The problem is that sometimes i fire the flash and it does images like this
IMAGE: http://farm3.static.flickr.com/2168/2539216128_364ef13fb9.jpg
It's really starting to bug me because I don't know how to fix it.. but like i said, it goes away when i change some settings but they aren't my desired settings.
Thanks to anyone who can help me
30D + 50/1.8 +18-55 + 420EX
http://www.flickr.com/​photos/nickhammondroxm​ysox/ (external link)
Titus213
May 31, 2008 11:59 |  #2
Your shutter speed is too high. What's the exif on this one?
Dave
Perspiring photographer.
Blender7
May 31, 2008 12:00 |  #3
Exposure: 0.003 sec (1/320)
Aperture: f/5
Focal Length: 50 mm
ISO Speed: 800
Exposure Bias: 0/3 EV
If i lower the shutter though the picture is completely blown out...
SkipD
Joined Dec 2002
May 31, 2008 12:06 |  #4
Blender7 wrote in post #5631171 (external link)
Aperture: f/5
Focal Length: 50 mm
ISO Speed: 800
The shutter speed needs to be slower for the focal plane shutter to be fully open when the flash goes off. The "maximum sync speed" (or "X-Sync speed) published in your manual is the fastest shutter speed at which the first blade of the shutter is fully open before the trailing blade starts its travel.
With a 30D and any conventional flash source, you need to use 1/250 or slower to avoid the black bar at the edge of the image.
If you are "blowing out" the image with a slower shutter speed, then the exposure is affected by the ambient light far more than by the flash. Your exposure bias may be having an effect here as well.
Skip Douglas
Titus213
May 31, 2008 12:09 |  #5
Look at flash photography as two pictures, one ambient and the other flash. Neither can be allowed to overexpose the image and must be such the together they don't overexpose. Camera in manual mode, meter to just under expose the scene with the camera for the ambient, let the flash do its thing.
Your shutter speed exceeds the max sync speed of the camera. Either lower that or put the flash in high speed sync mode and deal with the subsequent reduction in range.
Your ISO is too high and/or f-stop too low for the existing light. Reduce ISO or raise the f-stop.
And I assume the flash is in ETTL mode. Adjust the flash to balance exposure with FEC.
Dave
-MasterChief-
- B E L I E V E -
May 31, 2008 12:12 |  #6
lower your ISO! why 800? if you want to keep your aperture at f5, ISO 400 will take you down a full stop in shutter speed.
Curtis ­ N
Master Flasher
May 31, 2008 12:13 |  #7
Slow down the shutter speed, then either lower the ISO, stop down the aperture or reduce the flash power to control the flash exposure.
Curtis ­ N
Master Flasher
May 31, 2008 12:15 |  #8
Titus213 wrote in post #5631215 (external link)
I doubt it. He wouldn't be able to exceed X-sync speed with a dedicated flash attached. He's using a PC cord or radio trigger system.
And with the 420EX, there's no way to reduce the flash power when it's triggered via non-dedicated connection. So you're left with the other options.
Titus213
May 31, 2008 13:25 |  #9
Curtis N wrote in post #5631243 (external link)
Ouch, you are correct as usual. I realized after my post that it was a 420EX and limited in capability. But I didn't catch the inability to exceed sync speed.
I did noticed that the OP has a strange, apparently hairless critter lurking in the background.
Dave
René ­ Damkot
May 31, 2008 14:45 |  #10
If a slower shutter "blows out" the background, and the blowing out is done by ambient, there would still be plenty of ambient in the lower part of the image here, not a *black* bar. Also, if that were the case, what we see would *not* a sync speed issue, but instead a trip to Canon for a camera repair...
However, I think (hope) I see a tiny bit of detail in the lower left of the black bar, so I don't think the "blowing out" could be caused by ambient untill the shutterspeed is at least 5 stops slower.
So, I think this is an almost 100% flash exposure, and some other issue is causing overexposure when slowing down the shutterspeed.
If the *only* flash used is the hairlight from behind, then this is camera failure.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Blender7
May 31, 2008 15:08 |  #11
Thanks guys, the only flash that was used was the 420ex from behind. I have since been playing with shutter and aperature and ISO and it gives me what I want.
For this shot I was using cactus triggers and they have misfired a few times but this image does not have anything to do with the triggers because I have this problem when I shoot with the flash on my hotshoe.
azpix
May 31, 2008 15:12 |  #12
what is that behind her to the right?
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
René ­ Damkot
May 31, 2008 15:21 |  #13
Blender7 wrote in post #5631959 (external link)
Okay, so the main light is ambient from the front? (Somehow I doubt that; wishful thinking)
In that case, I think either your shutter is broken or, more likely, the sub-mirror assembly is...
Edit: I saw you "got what you wanted", so the wishful thinking paid off ;)
If the main light on the front is reflected flash (well possible), the "blowing out" is not caused by ambient, so I'm curious to one of the "blown out" shots, as well as one without flash.
Blender7
May 31, 2008 15:39 |  #14
the shot i posted had literally no ambient light. I was in a dark basement. And its weird that whenever I shoot above 250 sync speed that black bar comes up. I just did a test however and i did one shot with the flash using the cactus trigger and shot it at 320 and that black bar came up, I then took the flash and put it on my hotshoe and did the same shot and there was no black bar....This is too confusing.
Manticorp
May 31, 2008 15:47 |  #15
Ahaaa this is because your cactus trigger does a couple of things
the main thing being it disables E-TTL flash :lol: hence anything above x-sync is not possible
Also, there's eeeever so slighty more lag between sutter release and flash, reducing the flash x-sync slightly.
Hope this answers your question?
Will respond if it doesn't :)
I bought a cactus yesterday, came today, great little things :P
2,402 views & 0 likes for this thread, 10 members have posted to it.
2802 guests, 163 members online
