I shot some skateboarding on Friday. Here's what happened:
#1 - #4 shot with 350D + Canon 15mm f2.8
#5 - #8 shot with 350D + Sigma 70-300mm f4-5.6 APO DG
Comments please : )
WiK1d Member 44 posts Joined Mar 2008 More info | Jun 01, 2008 10:28 | #1 I shot some skateboarding on Friday. Here's what happened: #1 - #4 shot with 350D + Canon 15mm f2.8 #5 - #8 shot with 350D + Sigma 70-300mm f4-5.6 APO DG Comments please : ) Canon 7D | Canon EF-S 18-135mm | Canon EF 85mm f1.8 | Canon EF 70-200 F4L
on_ice Member 159 posts Joined May 2008 More info | Jun 01, 2008 19:40 | #2 I like number 6! Where is this located? Rebel XTi, 18-55 Kit, Tamron 18-250,
tennski19 Mostly Lurking 15 posts Joined Mar 2008 Location: Roanoke, VA More info | Jun 01, 2008 19:53 | #3 try not to get any butt shots, its tough sometimes, but you have to understand the trick and whether the skater is goofy or regular to set yourself up. Xti w/grip, 28-105 f/3.5-4.5, 50 f/1.8, 70-200 f/4L, 430ex
sacral Senior Member 633 posts Joined May 2008 Location: Wilmington, NC More info | Jun 01, 2008 22:30 | #4 |
jbergdoll Goldmember 1,176 posts Joined Apr 2008 Location: Tempe, AZ More info | Jun 01, 2008 23:28 | #5 Permanent bantennski19 wrote in post #5639316 try not to get any butt shots, its tough sometimes, but you have to understand the trick and whether the skater is goofy or regular to set yourself up. show the whole skater's body, boards can look cool, but to get the full effect you need to show the whole skater invest in some off-camera flashes, even during the middle of the day, they enhance your shots immensely, it will also allow you to up the shutter speed you need to show some more of the gap, jump, etc... like in the first one, show what he is gapping off of, he looks good in the air, but it doesn't really show what he's doing much. hope that helps, and if you haven't already, check out www.skateperception.com Was going to type all of this but thankfully, tennski did it for me. -Joseph
Jun 02, 2008 05:34 | #6 on_ice wrote in post #5639240 I like number 6! Where is this located? Thanks, it was shot at a mobile skatepark setup on a church's grounds, Pretoria, South Africa. tennski19 wrote in post #5639316 try not to get any butt shots, its tough sometimes, but you have to understand the trick and whether the skater is goofy or regular to set yourself up. show the whole skater's body, boards can look cool, but to get the full effect you need to show the whole skater invest in some off-camera flashes, even during the middle of the day, they enhance your shots immensely, it will also allow you to up the shutter speed you need to show some more of the gap, jump, etc... like in the first one, show what he is gapping off of, he looks good in the air, but it doesn't really show what he's doing much. hope that helps, and if you haven't already, check out www.skateperception.com The problem with the "butt shots" is that most of the guys were regular, and the sun was useless if you shot from the other side. But thanks for that, I'll keep it in mind! Canon 7D | Canon EF-S 18-135mm | Canon EF 85mm f1.8 | Canon EF 70-200 F4L
dontdrinkpepsi Member 37 posts Joined May 2008 More info | Jun 02, 2008 16:58 | #7 agreed
l+Jarrod+l Member 135 posts Joined Mar 2008 Location: GC More info | Jun 02, 2008 20:57 | #8 |
| Latest registered member was a spammer, and banned as such! 2803 guests, 159 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
