Thread started 02 Jun 2008 (Monday) 14:48
Flash with softbox
lbecerra
Jun 02, 2008 14:48 |  #1
Hi all,
I have read a lot here about light settings and all that, I have a alienbees 800 but is onlyone, I need to buy an external flash and I would like to know how good would the flash be (for example 580ex II) with a softbox as a second light?
also where can I get a softbox adapter for this?
thanks
Gear: Canon 5D Mark II
Canon 40D with kit lens EF28-135 IS USM f/3.5-5.6
Canon 70-200mm f/2.8 L
Canon EF 50mm f/1.8 II
TMR ­ Design
Joined Feb 2006
Jun 02, 2008 14:53 |  #2
Firing Speedlight's in to a small to medium softbox works very well but if you're going to want some distance between the softbox and your subject then there's a good chance you're run out of fire power. At close range you can easily use a Speedlight in a 24" x 32" or 36" x 48" and get some very nice results.
Robert
lbecerra
Jun 02, 2008 14:59 |  #3
Ok, what would be the results using this as a second light because I have a alienbees 800, I just want to kill the posible shadow and since I need I need to buy a external flash i was thinking that instead of using reflectors I can use the flash.
please give me some light LOL
TMR ­ Design
Joined Feb 2006
Jun 02, 2008 15:29 as a reply to  @ lbecerra's post |  #4
A Speedlight used for fill is a better idea. Just be careful with your white balance if you're mixing strobes.
For fill you can fire in to a silver umbrella, through a diffusion panel, in a softbox or octabox. It all depends on the type of lighting and shot you're trying to create.
Robert
lbecerra
Jun 02, 2008 15:33 |  #5
Is there any place that you know that I can get this (tripod, umbrella, softbox, diffusion) flash setting?
thanks
TMR ­ Design
Joined Feb 2006
Jun 02, 2008 15:56 |  #6
lbecerra wrote in post #5644540 (external link)
thanks
I'm not sure I know what you mean. Can you better explain?
Robert
lbecerra
Jun 02, 2008 15:59 |  #7
I have seeing like a normal tripod stand and a normal softbox that you would use with the alienbee 400 or 800 but a canon 580ex II flash mounted instead.
Have you seen that before?
1,836 views & 0 likes for this thread, 2 members have posted to it.
Flash with softbox
2801 guests, 162 members online
