Anyone know what I have to do to get rid of these darn things? I get one with every image I convert using the CS3 RAW converter. I've searched through the settings, but couldn't find anything.
...Or do I have to just live with them
Jun 03, 2008 00:18 | #1 Anyone know what I have to do to get rid of these darn things? I get one with every image I convert using the CS3 RAW converter. I've searched through the settings, but couldn't find anything. www.garyhebdingjr.com
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Jun 03, 2008 00:33 | #2 |
dfindr Senior Member 676 posts Likes: 1 Joined Oct 2006 Location: Gilbert, Arizona More info | Jun 03, 2008 00:47 | #3 gary88 wrote in post #5647763 Anyone know what I have to do to get rid of these darn things? I get one with every image I convert using the CS3 RAW converter. I've searched through the settings, but couldn't find anything. ...Or do I have to just live with them ![]() The delete key!. If you don't want them just delete them. They are nothing more than a sidecar file for your raw conversion which stores whatever adjustments you made to the specific raw file. However, if you delete these xmp files, you will have to convert your raw files again. REPEAT -- if you delete the xmp files you will lose whatever adjustments you made to the specific raw file which will require you to re-convert your raw files. DAVID ALAN DARBY // MAC CONVERT // Raging and unapologetic L'coholic constantly Striving To Measure Up to the Quality of My Gear!
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jun 03, 2008 00:49 | #4 They're essential, don't delete them. Why do you care if there are xmp files? I use bridge for everything and don't even notice them. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 03, 2008 01:17 | #5 dfindr wrote in post #5647883 However, if you delete these xmp files, you will have to convert your raw files again. REPEAT -- if you delete the xmp files you will lose whatever adjustments you made to the specific raw file which will require you to re-convert your raw files. This is incorrectly stated. It should read, "If in the future you want to convert your RAW files again, you will have to re-edit them." You don't have to re-convert them unless you want to. Elie / אלי
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jun 03, 2008 04:42 | #6 You could convert to DNG... "I think the idea of art kills creativity" - Douglas Adams
egordon99 Cream of the Crop 10,247 posts Likes: 3 Joined Feb 2008 Location: Philly 'burbs More info | I prefer the raw edits being stored in the XMP files. It makes my nightly backups MUCH quicker. Rather than re-copying over EVERY DNG file I worked on that day, I just need to grab the changed XMP files. I also prefer that the original CR2 file is UNTOUCHED.
davidcrebelxt Goldmember 3,016 posts Joined Dec 2006 Location: Missouri, USA More info | Jun 03, 2008 07:21 | #8 Not 100% positive, but I think in DPP you can choose to have it written out to a seperate file as well. David C.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jun 03, 2008 07:36 | #9 davidcrebelxt wrote in post #5648975 Not 100% positive, but I think in DPP you can choose to have it written out to a seperate file as well. Not AFAIK. "I think the idea of art kills creativity" - Douglas Adams
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 03, 2008 09:14 | #10 Originally Posted by davidcrebelxt
That is the same thing. It contains all the editing (except cloning) but it is not linked to the .CR2 and has to be loaded manually. Elie / אלי
I usually just delete them after I convert the RAW file to a high quality JPEG. Then if I need to make adjustments to the image, I just work off the JPEG, but save it as a separate file, keeping the original. www.garyhebdingjr.com
c71clark Senior Member 466 posts Joined May 2007 Location: NYC More info | Jun 03, 2008 18:56 | #12 Converting to DNG does not modify the original raw file in any way. It simply wraps it inside the Adobe format, which, quite nicely, includes all the XMP data. No more sidecars! It is another step in your workflow, but with an image ingesting program (I use the aptly named Image Ingester), it's just a part of the automation. Canon 40D w/grip, 85mm f/1.8, 50mm f/1.8, 20k lumen studio fluorescent DIY light kit, 2 strobe studio kit, 580exII, PW's.
GlennNK Goldmember 4,630 posts Likes: 3 Joined Oct 2006 Location: Victoria, BC More info | Jun 03, 2008 19:36 | #13 gary88 wrote in post #5649959 I usually just delete them after I convert the RAW file to a high quality JPEG. Then if I need to make adjustments to the image, I just work off the JPEG, but save it as a separate file, keeping the original. I suppose I could just keep the XMPs from now on. Thanks for the comments. My own personal comments on this are: When did voluptuous become voluminous?
| Latest registered member is semonsters 1012 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
