Thread started 03 Jun 2008 (Tuesday) 12:52
580EX II sync to 8.5fps ?
equetefue
Gallery: 230 photos
Jun 03, 2008 12:52 |  #1
How do you set-up for the flash to sync at 8.5fps ?
I selected the flash to sync but don't get flash with every shot, and if I deselect the high speed sync, I get limited at 1/250sec
http://www.Photo-Galleria.com (external link)
Powered By Canon
EOS R l 5D MkIV l 7D MkII l 5D l 30D IR l 500mm f4 L IS l RF 24-105mm f4 L l 50mm f1.8 l 17-40mm f4 L l 135mm f2 L l 100-400mm f5.6 L L IS II l 100mm f2.8 USM Macro l EF 1.4x III l EF 2.0x III l 580EX II
Nick ­ Pro
Jun 03, 2008 12:59 |  #2
1/128 power. Only way. thats how I got this
IMAGE: http://farm4.static.flickr.com/3281/2468613529_3c026504dd.jpg
PacAce
Joined Feb 2003
Jun 03, 2008 13:29 |  #3
If you need more power (than the 1/128 shown above), set the flash to 1/8 power and then hook it up to an external battery pack. You'll be able to easily do 10 fps for several seconds at that rate. Don't overdo it, though, unless you want to burn out your flash. :)
...Leo
Colorblinded
Gallery: 18 photos
Jun 03, 2008 13:31 |  #4
You don't need to do anything fancy, necessarily. Just have the camera set for 8.5 FPS, slap the flash on in full auto ETTL let it rip.
You'll lose frames however if you're trying to get too much power from the flash. Upping the ISO or opening the aperture will drive down how much power you need from the flash. That will help it keep up with 8.5fps shooting.
http://www.colorblinde​dphoto.com (external link)
http://www.thecolorbli​ndphotographer.com (external link)
equetefue
Gallery: 230 photos
Jun 03, 2008 13:32 |  #5
so 1/128 of power with main batteries and 1/8 with a quantum or such right ?
Thanks so much guys..
I'll give a try ..
I need it for birding so it will be 3-4fps burst here and there.. Using a better beamer
Powered By Canon
PacAce
Joined Feb 2003
Jun 03, 2008 13:35 |  #6
equetefue wrote in post #5651135 (external link)
I'll give a try ..
At 1/8 power, you'll be able to shoot 7 or 8 frames with just the internal batteries. You'll only need an external power pack (even the Canon pack will do) if you want more than eight continues frames without any interruption.
...Leo
equetefue
Gallery: 230 photos
Jun 03, 2008 13:47 |  #7
If I set-it to High speed sync it will go above the 1/250 speed but won't do every frame
If I select manual 1/8 or manual 1/128 it will go just to 250th of a second and I need a lot fast for birding.
Kind of confused as to what to set it to
Powered By Canon
Curtis ­ N
Master Flasher
Jun 03, 2008 14:57 |  #8
You can set it in manual mode and enable high speed sync, allowing for any shutter speed you like.
Pay attention to the distance scale. HSS will require a higher power level to get the same distance.
1,166 views & 0 likes for this thread, 5 members have posted to it.
2676 guests, 164 members online
