Thread started 03 Jun 2008 (Tuesday) 13:22
Polarizing filter help
Christina
Jun 03, 2008 13:22 |  #1
I shot some images of a cathedral reflected in the windows of a building across the street on my lunch break yesterday. I was using a Tamron 17-50mm lens with a polarizing filter... which from what I understand, is supposed to reduce glare. However I clearly did something wrong, as my images all came out looking like this:
I've really been enjoying POTN and have learned a lot by lurking over the past couple months. :) I'm hoping someone might be offer some tips about how to correctly use a polarizing filter... I seem to have the wrong way down already.  :o
Christina - Pittsburgh Wedding Photographer (external link)
Syncopated Pictures (external link)
http://christinamontem​urrophotography.com/bl​og/ (external link)
timnosenzo
Jun 03, 2008 13:56 |  #2
Did you try twisting the filter while looking through the viewfinder? You should notice a difference in the effect when you do.
rammy
Joined Oct 2004
Jun 03, 2008 14:08 |  #3
Where was the sun in relation to your target/shooting line? It should be at 90 degrees and you need to twist the end of the filter, as suggested, to see the effect.
Gear | Surrey Wedding Photographer (external link) | Surrey Wedding Photographer Blog (external link) | London Architecture Photographer (external link)
Christina
Jun 03, 2008 14:20 |  #4
timnosenzo wrote in post #5651299 (external link)
I didn't try that. But I will, thanks.
I'm not sure how to figure where the 90 degrees comes from. Do I envision a line between the camera and the subject, and then the sun needs to be at a 90 degree angle from that line?
rammy
Joined Oct 2004
Jun 03, 2008 14:27 |  #5
The easiest way to remember is that the sun should be to your left or right and the subject in front of you.
WaltA
Gallery: 10 photos
Joined Feb 2006
Jun 03, 2008 14:27 |  #6
MonteMama wrote in post #5651476 (external link)
Check out the explanation in this article
http://www.great-landscape-photography.com/polari​zing-filter.html (external link)
Walt
400D, 5D, 7D and a bag of stuff
Christina
Jun 03, 2008 15:05 as a reply to  @ WaltA's post |  #7
Thanks for the link. I think that makes sense - will have to give it a try on our next sunny day. They do happen in Pittsburgh a couple times a year.
iamaelephant
Jun 03, 2008 17:17 |  #8
The angle of the sun is irrelevant with regards to window reflections. That 90 degree figure applies only to a polarizing effect in the sky.
-- Martin
Canon 30D | Tamron 17-50mm f/2.8 | EF 50mm f/1.8 II
Christina
Jun 03, 2008 18:59 |  #9
iamaelephant wrote in post #5652674 (external link)
Oh. So... can I fix what happened above by turning the filter? Or is there something else I should do?
Glenn ­ NK
Jun 03, 2008 19:09 |  #10
One other thing to keep in mind about polarizers - they have little effect on metallic surfaces, and I believe this includes glass surfaces.
I've worn polarizing glasses and sunglasses for years, and the glare from the rear window of a car in front of me doesn't seem to be affected by the polarizing sunglasses.
OTH, the glare from objects like water and leaves will be greatly diminshed.
By rotating the filter slowly while looking through the viewfinder, the effect you are going to get should be visible.
When did voluptuous become voluminous?
Mark1
Jun 03, 2008 19:11 |  #11
Just spin the filter while looking through the camera. You will see the effect change intensity. You can even hold the filter in front of you, and look at the monitor through it. Rotate is and you can see it change. You dont need a sunny day to take advantage if a CP. Just need reflections or glare.
Mark1
Jun 03, 2008 19:14 |  #12
Glenn NK wrote in post #5653428 (external link)
Rotate your head (ear to sholder) You will see it change. My sunglasses are polarized as well. With the flurry of questions here. It is in the back of my mind. So I have been playing with them a bit while driving.
They reduce glare on glass. But they can almost eliminate reflections on glass.
iamaelephant
Jun 03, 2008 19:52 |  #13
MonteMama wrote in post #5653353 (external link)
To a limited degree, yes. I would advise taking your CPL out on a nice day and experimenting to find out what is possible.
-- Martin
DStanic
Jun 03, 2008 19:57 |  #14
If you want to see the effects of a CPL filter, put some uncovered boiling water on the stove and turn on the light above the oven. Look at it through the viewfinder and turn the CPL and you should be able to see the change in the reflection. At least I noticed it when I did it before.
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
Mark1
Jun 04, 2008 00:23 |  #15
Just noticed in the OP..... there is no glare to reduce.... those are reflections. But still a CP will help.
2,256 views & 0 likes for this thread, 10 members have posted to it.
2675 guests, 162 members online
