Thread started 04 Jun 2008 (Wednesday) 02:54
When doing a photoshoot.....
RichSoansPhotos
Jun 04, 2008 02:54 |  #1
What the best settings to use? Aperture Value (Av) or Manual, or even Timing Value (Tv)?
It looks like the place is going to be inside a studio or if I can get another building than my own
And I am photographing people as for a portfolio
jhuse
Jun 04, 2008 04:07 |  #2
Depends on what kind of lighting you are going to use? Strobes, constant, etc. If using strobes you can sync in aperture up to 1/200 sec depending on the setup and set for aperture according to depth of field needed and amount of light used. Manual is basically the same thing only you will have control over shutterspeed as well, in case a blur is wanted etc. but you wont be able to go over 1/200 sec even in manual before you start to see the bottom of the shutter showing in the images without more equipment. If using Tv strobes wont really do much cause the camera will meter your aperture for for ambient light and your images will blow out every time. This would work better for constant lighting. A light meter would also be a very handy device to have and just work in manual with the camera and play around till you get the mood and lighting that suites your taste. Hope this helps a little. If you could list the type of lighting equipment you will be using it might be a little more helpful.
Jeremy
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 04, 2008 11:06 |  #3
Incandescent lights: Try manual in those tough conditions. First set the f-stop & shutter speed you need. Then adjust the ISO. Need an exposure crutch?
This shows how the subject can affect the exposure & why manual keeps me worry free: Post #47
Strobes:
My 1-cent flash "meter" in images 5S & 6S.
Simple 2 Light Portrait Set-up
richy5497
Jun 21, 2008 12:57 as a reply to  @ PhotosGuy's post |  #4
Are your lights going to be made of glass or plastic? There is a huge difference as plastic bulbs tend to melt easily.
http://www.rgbrowne.co​.uk (external link) (Gallery being updated)
Canon EOS40D.
580EX Speedlite, Tamron17-50mmF2.8 VC(LOVELY) , Canon EF50mmF1.8, Tamron 90mmF2.8Macro, Tamron 55-200F4-5.6, Canon EF18-55mmF3.5-5.6, Tamron 10-24mmF3.5-5.6DiII.
733 views & 0 likes for this thread, 4 members have posted to it.
2951 guests, 157 members online
