MT Stringer wrote in post #5667002
Pat, if you haven't tried out Breeze Browser, you need to. I use it all the time. According to Breeze, your center focus point was dead center on the pants zipper.
Has this image been altered (cropped, PP) any?
I downloaded your pic and did a little tinkering in Paint shop pro and it sharpened up pretty good except for the motion blur. The ground underneath and around him looks sharp.
Hope this helps.
Mike
I'd like more information on Breeze Browser! Yes, the center point I had been aiming for beltline/chest. I probably dipped alittle under that, because in addition, I'm trying to center the person in between the 4 x 5 crop lines so that ***if*** I can a terrific shot, then I can crop to a 4 x 5 ratio. If I raise that center point up more higher on the chest, then, what is going to happen is that the feet part will get cut-off if I decide I want a 4 x 5 crop later (some of the boys are bigger - and this kid is one of them). Given what is happening here (and Mike bless you for pointing that out), when shooting vertically, should I be using a different focus point, in light of the fact that I am also trying to compose for possible 4 x 5 cropping later? Or, should I not be so worried about 4 x 5 cropping? (I am using a 30d - so I don't know how sensitive the northern focus point is). I hope I'm explaining this so you understand what I mean.
Yes, I noticed that the ground underneath him looks pretty sharp in this shot. When I use a canon lens (specifically the 70-200), if I raise the center point too high and too close to the upper chest, I will blow out focus on the face, but on this lens, it seems like if I am too far down, the focus will shift down.
As to your question about PP, I probably did a crop, and an overall lightening of the photo using the CS2 screen method, but nothing else and no USM applied. Even though I only took it yesterday, I can't quite remember what I did before posting, but I know for sure I did not apply any USM.
Thanks!
Pat
