Thread started 04 Jun 2008 (Wednesday) 19:45
POLL: "Which do you use with your monopod?"
ball head
32
36%
flip head
23
25.8%
no head
34
38.2%
89 voters, 89 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
Monopod Users
jr_senator
Jun 04, 2008 19:45 |  #1
Which do you use on your monopod? Ball head, flip head or no head? I use a ball head because sometimes I rest my monopod against a fence, tree, building, etc. at an angle.
Grentz
Jun 04, 2008 23:44 |  #2
Flip head ( I assume you mean like the 3229)
Search.TechIslands.com (external link) - Photography Shopping Search Engine
www.TechIslands.com (external link) - News and Reviews
My Gear List - 60D
Mark1
Jun 05, 2008 00:15 |  #3
I have a Slik Quick Pod. It has a top ( not really a head ) that can go 90 degrees to either side. Or if you turn it, front to back.
ed ­ rader
"I am not the final word"
Jun 05, 2008 00:22 |  #4
jr_senator wrote in post #5661376 (external link)
i use a 3229 tilt head. with the RC2 plate mounted long ways on the tripod mount of my 100-400L i can quickly tilt the lens up and down, and i use the tripod mount to switch camera orientation.
i use my monopod alot to shoot down into a lagoon and the tilt head makes it much easier.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
RPCrowe
Joined Nov 2005
Jun 05, 2008 00:40 as a reply to  @ ed rader's post |  #5
Kirk MPA-1
The Kirk MPA-1 is a Manfrotto 3232 Monopod Swivel Tilt Head with a Kirk quick release installed.
It allows me to use Arca Compatible accessories including a Really Right Stuff 30D L-Plate. This L-Plate places the camera directly above the monopod shaft, instead cantilevered of off-side, which greatly increases the stability of the combination.
http://reallyrightstuf​f.com/QR/04.html (external link)
Since my tripod is equipped with an Arca Compatible Q.R. system, I wanted that type of system for my monopod. I seldom remove the lens plates from the tripod rings of my long lenses and often shoot my 30D while the L-Plate is still mounted.
PBest78
Jun 05, 2008 05:00 |  #6
I voted for flip - Im assuming you mean a tilt head.
I bought a cheap pod from jessops and it came with the head (permanently attached) so dont really have a choice!
Peter
Peter
darkvibe
Jun 05, 2008 11:41 |  #7
No head. I turn the camera and lens in the lens' tropd mount to shoot vertical.
http://www.darkvibe.or​g/gallery/ (external link)
Canon 30D w/ grip, 18-55mm kit lens, Canon 24-105mm f4L IS, Tamron AF 28-300mm f3.5-6.3 XR DI, Canon 50mm f1.8 II, Sigma APO 50-500mm F4-6.3 EX DG HSM, Sigma EF 500 DG Super, Slik Pro 400DX tripod, Slik Pro Pod 381 CF monopod.
Jon
Joined Jun 2004
Jun 05, 2008 12:44 |  #8
Ball head - I don't always use it with lenses that have mounting rings and I'm likely to want to tilt the tripod and the camera in different directions.
Jon
Cocker Spaniels
malla1962
Joined Jul 2004
Jun 05, 2008 13:05 as a reply to  @ Jon's post |  #9
I tried a 3232 with a RRS clamp on with my 500f4 and found it totaly crap, now I just have the RRS clamp on the pod and works great.
Tom_D
Jun 05, 2008 19:22 |  #10
I have the Manfroto 680B Monopod w/322RC2 Grip Action Ball Head and 322RS Electronic Shutter Release. The cable for the 40D is coming. This setup puts your thumb on the shutter button as you grip the ball head handle.
Gallery (external link)
7DMkII, 40D, 17-55, 70-200 f/2.8 IS and more...
More Wag, Less Bark
GSansoucie
Jun 05, 2008 19:57 |  #11
Jeesh, I can't image the train wreck that would ensue with a ball head on a monopod (and Quick Release Plates). . .
-=Glen=-
Flickr Stream (external link)
Check out my 2010 PaD (external link)
http://www.pbase.com/g​sansoucie (external link)
RichNY
Jun 05, 2008 20:11 |  #12
A lot of the decision whether or not to use a 'flip head' like the 3232 will depend on the size of the glass you are mounting on it. I use one with a 200 f/2 and it is fine but I wouldn't use it if I had a 400 f/2.8 or longer glass.
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
Eagle
Gallery: 62 photos
Jun 05, 2008 20:33 |  #13
3232 tilt head
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
b.d.bop
Jun 05, 2008 22:16 as a reply to  @ Eagle's post |  #14
Really Right Stuff just came out with their new MH-01 High Capacity Monopod Head (external link) <----click
Ought to be a big seller, I'd imagine. :)
Dr. Mark Polis 1DsIII | 7D
the Gear Arsenal | flickr (external link) | PBase galleries (external link)
malla1962
Joined Jul 2004
Jun 06, 2008 01:18 |  #15
b.d.bop wrote in post #5669648 (external link)
Now that looks interesting.;)
1,852 views & 0 likes for this thread, 17 members have posted to it.
Monopod Users
2829 guests, 175 members online
