I understand the need for especially sports to use a monopod with heavy lenses, that part's clear. But I've been wondering if it would be worth it to get one for my general walk around stuff to have with me when I'm shooting the 70-200, often with 1.4x and 2x tele-extenders.
Yes I have a tripod but seem to only use it for table top setups. When outside shooting things like flowers I can't generally push the tripod into the bushes well enough or theres a rock wall in the way etc, and I stopped carrying it with me. I'm usually down on my knees scooting in as close as I can get and wondered if the single leg of the monopod might help. But it's an expensive experiment if I do what appears to be best.
I've shot many a closeup with extension tubes on my 70-200 hand held with wonderful results, generally having more movement problems related to a breeze moving the plant than my own self shaking the camera. I do get very patient when doing this and take my time getting it just right, a little move over an inch or two to the left or right can make a huge difference and moving a tripod in this scenario is frustrating.
So a little while ago I set up my 5D w/70-200/2x tele-extension and put it at full telephoto (400mm just to test the extreme) and then found something at it's closest focus to shoot thinking that would be the easiest test to show movement.
I first put the setup on my tripod with only one leg extended, a Manfrotto 055MF4 carbon tripod, granted it's a 4 section tripod and with one leg it might be a little light but what I noticed most was my own side to side swaying when holding on the subject.
Just like when hand held, the IS helped enormously.
I'd shoot, trying to see how low I could go shutterwise which was around 1/25th of a second with me fresh, not all tired out from hiking around.
Then I took it off the tripod/monopod and noticed just about the same results.
Am I missing something? Somehow I think I must be leaving something out of the equasion. Admittedly when out getting shots of things like Seagulls and Herons I seem to have to use at least a 200th of a second or more for static shots, and yes more helps a lot, moving shots of course take a lot more shutter.
I have been looking over at RRS at their new heavy duty swivel with the idea of putting it on the heavier Gitzo Monopod I think it's the 5540, or even the lighter 2541 they list, with the intention that in a little rougher terrain down at the beach I can use the monopod (carefully of course because it's carbon) as walking support-that parts just a thought but it might make sense where footing might be a little unsteady (legs/knees are not what they used to be). Yes I looked at that combination monopod/walking stick in another thread here on this forumn and it looked a bit light, especially the connection setup to the camera..
I like the heavier monopod idea also just because my experience is to have something solid under the camera and not try to go to light, but carrying a tripod just hasn't worked out, I have too many shots where I've got to swing fast to grab the shot and maybe there is a way I can carry the monopod also slung from my shoulder or waist?
But after these tests, I'm starting to think I might want to scrap the whole idea for the setup I have, it's a lot of money to put into an experiment. Like I said, if I was shooting lots of sporting events then it makes a lot of sense, espeically if you're hopping around one area for a couple of hours trying to get shots.
Any ideas? If I do it, I want it to be solid, I bought a real light Manfrotto monopod years ago and used it once, I could feel the flex and gave up on it right away.
