Thread started 08 Jun 2008 (Sunday) 14:40
Please Help!
Thenicky
Jun 08, 2008 14:40 |  #1
Im very new to photography! And im trying to practice where i can and i figured id practice portraits inside my house.
i have a 500 watt hot light. 3x3 foot PVC Square and i put a sheet inside to soften the light...
#1 I want a black background. Which material should i use i dont want any reflection off it i want it a solid flat black...
#2 Should i just hang white sheets on the sides of my background and let the light hit the enitre sheet or what...
#3 WHich settings should you typically be at or try to achieve doing a black background portrait...
I soon will buy lighting and plan to.. for now this will do becuas ei bought my camera 2 weeks ago and id rather practice with this before dropping 500 on a nice set of light...:oops:
[One Vision Two Eyes]
Canon XTI, 18-55mm, 50mm 1.8 W/ Hood, Tripod, UV And CP Filters. And Big Dreams
Curtis ­ N
Master Flasher
Jun 08, 2008 17:21 |  #2
1. Black velvet or velour, though in reality, as long as it's several feet behind your subject then anything black will work.
2. I don't know why you would want sheets on the sides of your background.
3. You'll need to meter it and do a bit of trial and error. With only 500 watts of continuous light for a portrait, I would recommend a tripod to allow some fairly slow shutter speeds. Use a high enough ISO so you can get your shutter speed up to about 1/30 to avoid subject movement.
Thenicky
Jun 08, 2008 17:24 |  #3
Thanks Alot Curtis. I said sheets on the side cause i figured it would some what work as a softner to my 500w but then again im so clueless so hey curtis is my position with my stuff what would you do...
Curtis ­ N
Master Flasher
Jun 08, 2008 20:06 |  #4
First, learn about light. There are some concepts that you'll need to understand to get predictable results. Here's a good place to start:
http://strobist.blogsp​ot.com (external link)
While you're learning, practice. Put each individual concept to work.
Be patient with yourself. No one learns this stuff overnight.
799 views & 0 likes for this thread, 2 members have posted to it.
Please Help!
2841 guests, 167 members online
