One of the (only) common problems with this lens. Yes, the front element retaining ring is coming loose. You can either: a) send it to Tamron for repair. or b) fix it yourself in about 10 minutes.
I chose B). Get a set of precision screwdrivers, take the smallest flathead one and slip it under the little notch in the ring at the front of the lens (right near the front element. Go around the edges to pop out 3 tabs holding the ring in place (the ring is flexible, and you might need some force, but you shouldn't break the ring...it seems quite sturdy, still be careful.) There are three small phillips head screws under the ring...take the smallest phillips head screwdriver in the precision set and tighten all three. If you want to not have to do this again, you may want to remove the screws, put a tiny dab of lok-tite on it and then retighten. I did not use lok-tite, and mine's been fine since. Pop the ring back on the end by putting the tabs in the holes they fit in, and press down to snap into place (use something hard but with a soft edge, like a Q-tip or something, or you may flatten the little ridges in the ring). You're done!
Please note that this is at your OWN risk, and I take no responsibility should you damage your lens by doing the repair yourself. My repair was fine, easy and fast, but if you're not careful you could break the retaining ring or the screw cover ring, scratch your front element or something else.
