I am noticing that the white balance seems to look like it is not metering correctly. I don't know if a setting on my 40D is not set up correct or not because it looks like everything is fine.
Most of my pictures from Indoors seem to be very yellow in tint or reddish... I have tried changing multiple settings when using it but cant seem to correct it.
And when I am outside the colors just aren't that crisp. I always adjust my white balance depending on the situation, inside incandescent if no flash, using flash change to with flash, and ect. By doing this it still doesn't seem to adjust correctly. I just bought my 40D not that long ago so I don't know if maybe internally it wasn't calibrated right or if I just need to adjust a setting on it. I use a 580EX II. Is anyone else having this kind of problem with their 40D??
Anyone know what I need to change?
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
