Thread started 09 Jun 2008 (Monday) 18:52
C&C please Panning practice
midnight_rider
"Thrown under the bus."
Jun 09, 2008 18:52 |  #1
I was trying to practice panning and well the birds figured it was to hot to be out.
It got up to 100 today and I could not find one bird anywhere. So I threw a leaf.
I never, Not once claimed to read your post...
Brizboy
Jun 09, 2008 22:52 |  #2
I thought panning is to make the background have motion blur, to give the leaf an effect of movement? In this photo it doesn't look like u were panning with the leaf. But I could be wrong because i am no expert!
Maybe a slower shutter speed and close the aperture a bit? experiment i say.
Flo
Gimmie Some Lovin
Jun 10, 2008 09:36 as a reply to  @ Brizboy's post |  #3
I have noticed that in all your posts, there is heavy pixilation .birds and frog and this.hoping its just from compression...
LeuceDeuce
Jun 10, 2008 10:51 |  #4
Flo wrote in post #5695477 (external link)
It is. The image is 1024px wide and just under 25kb. That's some serious compression going on.
my website: Light & Shadow (external link)
my flickr (external link)
Flo
Gimmie Some Lovin
Jun 10, 2008 12:26 |  #5
LeuceDeuce wrote in post #5695931 (external link)
Thanks Chris, I thought it seemed intense.;)
midnight_rider
Jun 10, 2008 15:14 |  #6
I noticed that to. How do I resize these images without them turning out like this?
LeuceDeuce
Jun 10, 2008 17:04 |  #7
midnight_rider wrote in post #5697289 (external link)
Myself, I only post images that are 800 on the long side (usually 800x533). Unless I'm looking for technical help I don't bother with the EXIF information so I just use Save For Web in Photoshop. When I save I select to optimize the file size to 150k so I get the best possible quality at 800px long.
You can include your EXIF in the post if you are asking a "what went wrong?" type of question, but for composition questions it's really not required. Some folks may want to see the EXIF to compare your panning results to the numbers. You may have your shutter speed too fast/slow for panning and certain focal lengths, etc...
In this shot, for example, it appears that you have nice DoF blur in the background, but it doesn't look like the motion blur associated with a pan shot. I would suspect that you have quite a long focal length to throw the background OoF, but your shutter speed is quite high to freeze the action on the leaf. Without EXIF information though, this is mearly a guess. Because it's a guess, folks can't really comment on whether you have achieved a good pan shot, or just a sharp shot of a leaf in the air.
Bryan ­ T
Jun 10, 2008 17:07 |  #8
How do yall post at 800? canons only make good images at 900, when I do 800 it squishes up the picture.
Canon 300D / 17-85mm
LeuceDeuce
Jun 10, 2008 17:17 |  #9
Bryan T wrote in post #5697850 (external link)
I'm sorry but I'm not following you here. What makes you say canon only makes good images at 900px? When you reduce the long side to 800 are you reducing the short side by the same ratio? You have to maintain the aspect ratio of the image when you reduce it. I use the term "long side" instead of width or height because I don't know whether the image orientation is landscape or portrait.
Edit: yes I know that THIS image is landscape, but I don't know the orientation of future images :)
Bryan ­ T
Jun 10, 2008 17:22 |  #10
ok, when I open a photo in PS, the common size is 800x600. When I go to 800, it makes the other side 525 or 400 or whatever it is, I forgot. it looks squished, does not look right.
to keep that "800x600" size, I size them at "900x600" because when I size to 900, the other side falls into 600, and it looks correct, no squishing.
midnight_rider
Jun 10, 2008 17:23 |  #11
LeuceDeuce wrote in post #5697837 (external link)
Thanks i never tried the save for web option and I will try to keep it 800 on the long end and hopefully that will help my future post.
As for the shot, I have never really panned before so I did not realize that the motion blur was a must. This shot was taken at 200mm 1/400 so it is very frozen. Now I will have to try to get the motion blur down pat.
LeuceDeuce
Jun 10, 2008 17:32 |  #12
midnight_rider wrote in post #5697958 (external link)
Yeah panning is used to create a sense of motion in the image. What you were practicing was tracking (also good to practice since it's essential for panning). Just to practice the technique I'd go and shoot cars on a busy street.
DrFil
Jun 11, 2008 08:58 |  #13
Bryan T wrote in post #5697944 (external link)
that makes absolutely no sense. you must be doing something wrong. when resizing, try using file>automate>fit image and then changing the longer side to 800 pixels. that should make it look good at 100%.
Bryan ­ T
Jun 11, 2008 12:34 |  #14
no, Im not doing anything wrong. I was even warned about this when I got the camera, i was told it does not make perfect 800x600, and after playing with it I found that instead is makes 900x600. I keep "auto ratio" seclected, and thats what I get.
nm Ill just keep shooting in my "makes no sense" 900x600
LeuceDeuce
Jun 11, 2008 12:42 |  #15
Bryan T wrote in post #5702794 (external link)
You are shooting with a Rebel (300D) which indeed takes the picture at a ratio of 3:2 (900:600). Why you are concerned with 800x600 (ratio 4:3) I'm not quite sure. If you resize your images that come out of your camera, without cropping them, they will be 800x533. That's what I post. It's not "squished" so I'm not sure what you're seeing.
Edit: Posted the original image at 800x533, and I'm just not seeing anything squished.
_
2,589 views & 0 likes for this thread, 6 members have posted to it.
2823 guests, 169 members online
