I recently met with some people about school picture days and they provided me with a sheet about how they do their set-up. For instance, on sunny days, their flash setting is at AA with an ISO at 100. If you go "below" 5.6, use ISO 400. This wording confuses me a bit. Are they saying that rather than going with a wider aperture and getting too shallow a dof, up your ISO instead? That would make sense to me.
They also say for cloudy days, their flash setting is TTL-BL with an ISO at 400. Ok, so less sun, higher film speed. Then it says at F16 or higher, use an ISO at 100 (f/stops are not rounded up to avoid dark backgrounds). Does this mean they'd rather you use ISO 100 than go beyond F16 (say F22, or do they mean f8, etc.?). I get confused when it says "higher" as I think more in terms of wider or stopped down.
It also says when exposing for the subject, expose him/her to match the background (so we're metering for the background no matter what the conditions?). With a bright background, hold meter in the sun facing the camera and for a dark background, hold the meter under shade facing camera. Got to learn more about metering with a light meter!!
If anyone can help me a bit with this wording, I'd really appreciate it. I think once I see what they are doing in person, it will make more sense than when it's written on paper. At least I have found this to be true in most situations regarding photography.
They also always use manual instead of Av or Tv, so I'm going to do some serious practicing with manual again. Although I would be going by their fixed settings, I want to get more of a feel for why they are doing what they are doing, which is obviously very important.
Thanks much.
