Thread started 10 Jun 2008 (Tuesday) 20:31
At which aperture is this lens the sharpest?
seekphotography
Jun 10, 2008 20:31 |  #1
Is there a table with a listing of various lenses with the aperture at which their 'normally' known to be their sharpest?
I guess the rule of thumb setting is f/8 but from experience with various lenses like the 'kit lens' .. it starts getting really sharp when used at f/5.6 and up. etc.
Think it would be a good reference point for many members ...
a camera , a few lenses, various accessories and never enough time.
Mr. ­ Clean
Jun 10, 2008 20:33 |  #2
It varies on the lens and maximum aperture. F5.6 or f8 is usually tops.
You can try photozone.de
Mike
some shots @ Zenfolio (external link)
RPCrowe
Joined Nov 2005
Jun 10, 2008 21:01 as a reply to  @ Mr. Clean's post |  #3
Rule of thumb...
This is probably about as accurate as the shutter speed=1/focal length formula - which means not very accurate at all:
Lenses normally are sharpest about two stops down from their maximum aperture. However, there are some lenses such as the 400mm f/5.6L that are as sharp (and that is pretty darn sharp) wide open as when stopped down.
AeroSmith
Gallery: 46 photos
Joined Feb 2006
Jun 10, 2008 21:35 as a reply to  @ RPCrowe's post |  #4
"f/8 and be there" is the photojournalist's creedo.
But I've found almost all of the Canon lenses to be quite sharp stopped down one stop.
There are a few exceptions, lenses that rock wide open: 85L, 135L 200/2L....
Josh Smith
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jun 10, 2008 22:31 |  #5
Looking at photozone, it seems to be about 1-2 stops. The old adage was about 2-3 stops, so for a f4 lens that would be f8-11 but maybe modern lens design is getting better.
Gallery: http://tomyi.smugmug.c​om/ (external link)
BigBlueDodge
Jun 11, 2008 00:27 |  #6
There is no one single aperture that all lens are their sharpest at, simply because there a a wide range of max apertures lenses are sold with. In general, you will find that the sweet spot of most lens is about 2 stops down from wide open.
David (aka BigBlueDodge)
Gear
Sickness
Jun 11, 2008 00:31 |  #7
AeroSmith wrote in post #5699339 (external link)
Notice what letter each of those lens have in common... :)
Canon 20D
Canon 28-80 f/3.5-5.6 MK1 /
Zeiss 50mm f/1.7
Sigma 20mm f/1.8 / Canon 28-135 IS
thatkatmat
Gallery: 41 photos
Jun 11, 2008 01:08 |  #8
So, there you have it, about 2 stops, but as others stated, each lens is different. For instance, I've had 3... 50L's two of which were super sharp by 1.8 and didn't get much sharper past that, the 3rd, which I currently own is as sharp as the others at 1.4. Same with the two copies of the 100-400's I've owned, while both were sharper than some others I've seen, the one I own currently is sharper wide open than the first copy I owned....So, again, each seem to have their own individual "sweet spot", this is a "your mileage may vary" deal. I'm pretty sure humans make these lenses, so you will have variances.
My Flickr (external link)
Stuff
sboerup
Jun 11, 2008 01:20 |  #9
Agree with comments above. 85L is wicked sharp wide open, doesn't really improve stopped down.
1,551 views & 0 likes for this thread, 9 members have posted to it.
1757 guests, 175 members online
