Thread started 11 Jun 2008 (Wednesday) 11:22
gitzo tripod bags, series 2 in series 1 bag?
Kent ­ Clark
Jun 11, 2008 11:22 |  #1
At The Digital Picture the reviewer says:
"I recommend using Gitzo's dimensions to find the proper size case (models GE10P through GE15P) - not their recommended tripod fit."
The only problem is that Gitzo only gives exterior dimensions, not interior.
My Gitzo 2530 with Acratech Ultimate ballhead measures 28.75". The bag Gitzo recommends for series two tripods is the GE12P which measures 33.5" on the exterior. The Gitzo GE11P, which they say is for series 1 tripods, measures 30.3" on the exterior.
If the padding on each end is less than 3/4" my 2530 should fit in the series 1 bag and it would be a slightly smaller package than the series 2 bag. Does anyone out there have the Gitzo bag made for series 1, the GE11P? Would a 28.75" tripod/ballhead fit?
jmik26
Jun 11, 2008 13:21 |  #2
I wouldn't waste your money on the Gitzo bags. Take a look at the Thinktank Bazooka Tripod cases (scroll third of way down page). (external link)I have the Humongous Bazooka for my 5540 and the padding, build, ease of use, and price is outstanding....Jeff
www.jmikosphotography.​com (external link)
Kent ­ Clark
Jun 11, 2008 16:58 |  #3
Jeff, I've seen those mentioned in the forums but 6" diameter is too big. The reason I like the gitzo bags is they're padded but thin, 4" diameter. But thanks for taking the time to respond.
jmik26
Jun 11, 2008 17:20 as a reply to  @ Kent Clark's post |  #4
I needed the bigger diameter for mine, its 6.75". They do make a smaller one, which has a 5" diamter (external link). Wish I could help more on the Gitzo bag end of it...Sorry, Jeff
jhom
Jun 11, 2008 17:23 |  #5
I have a 2530 with a Markins Q3. When I use a case, my choice is the TT Bazooka. It fits great. I don't think it is too big.
Jim
jrsforums
Jun 11, 2008 17:26 |  #6
Kent Clark wrote in post #5704473 (external link)
You may want to consider this...
http://cgi.ebay.com …Q_trksidZp1713.​m153.l1262 (external link)
It is thinly padded. My 2541L w/ M-10 is 28.25" Add'l 0.5" will be a little snug, but easily fit.
I mainly use it only for protective storage.
95% of the time just use an Optech strap.....the one with the swivel snap on one end. I just put a small split ring up by the head using black cable tie. Works for me.
John
Kent ­ Clark
Jun 11, 2008 18:05 |  #7
John, thanks for the link. Ideally I'd like to have several bags in front of me to compare in person. My local camera shops both carry the bogen manfrotto bags and some tamrac bags, everything else is special order.
One thing I noticed in your reply. You have a 2541 and it's only 1/2" longer than my 2530? Whenever people discuss 3 section vs 4 section tripods here the 4 section crowd says that it's just as stable and folds up smaller for carryon, backpacking, etc. One half inch isn't that much smaller, assuming the two ball heads are about the same height.
jrsforums
Jun 11, 2008 20:27 |  #8
Kent Clark wrote in post #5704835 (external link)
2541L
Maximum Height - 68.9" (175 cm)
Maximum Height w/o Column Extended - 59.4" (151 cm)
Folded Length - 24" (61 cm)
http://www.bhphotovide​o.com …ountaineer_6X_C​arbon.html (external link)
Edit: Oh....and I have the Gitzo (short) spikes on it, which adds a little bit.
John
Kent ­ Clark
Jun 22, 2008 16:01 |  #9
I bought the Gitzo bag suggested for the 2000 series tripod. Very nice. The zippers are large and heavy duty, the shoulder strap connectors are metal, not plastic. They include a rainfly strip on the inside of the zipper.
I probably could have fit my 2530 and Acratech Ultimate in the 1000 series bag but this bag is slim, well made, easy to carry. No regrets, I'll never have to think about another tripod case, this one should last as long as I do.
1,587 views & 0 likes for this thread, 4 members have posted to it.
1125 guests, 125 members online
