Thread started 11 Jun 2008 (Wednesday) 13:03
CPF - do you remove UV filter when using CPF?
Cody21
Jun 11, 2008 13:03 |  #1
I have a UV "protective" filter to protect my main lens. My CPF screws directly onto that UV filter ....
Curious - do any of you actually remove your UV filter when using the CPF?
Seems like just 1 more layer of glass that I'm contending with..
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
nicksan
Man I Like to Fart
Jun 11, 2008 13:08 |  #2
I remove my UV when using the CPL or ND/GND.
Cody21
Jun 11, 2008 13:14 |  #3
Makes sense -- thanks !!
Double ­ Negative
*sniffles*
Jun 11, 2008 16:48 |  #4
Cody21 wrote in post #5703044 (external link)
...Seems like just 1 more layer of glass that I'm contending with..
Exactly. Unless you have a real reason to stack filters (CPL w/GND for example) try to avoid it for exactly the reason you mention.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
stuman16
Jun 11, 2008 17:02 |  #5
I leave my UV on when using my CP filter. I don't think a good UV filter degrades your image at all so I see no need to pull it off when I use the CP filter. When I buy a new lens I screw on a good UV filter and never take it off.
www.stumanphoto.com (external link)
Hermeto
Jun 11, 2008 17:49 |  #6
stuman16 wrote in post #5704493 (external link)
With stacking CPL on the top of UV filter, even the best one, you accomplish exactly nothing – other than losing 1 stop of light and possibly decreasing a bit of image quality.
DStanic
Jun 11, 2008 17:56 |  #7
I leave mine on, taking it off just risks getting fingerprints on the filter/lens. However, I'm not using a UV on my 70-200 because I think it might be causing issues (I've never had problems with any other lens).
Sony A6000, 16-50PZ, 55-210, 35mm 1.8 OSS
Canon 60D, 30D
Tamron 28-75 2.8, Tamron 17-35, Sigma 50mm 1.4, Canon 85mm 1.8
JWright
Joined Dec 2004
Jun 11, 2008 18:37 as a reply to  @ DStanic's post |  #8
It's not an issue for me since I haven't used a UV filter in 25 years...
John
Cody21
Jun 11, 2008 18:42 |  #9
JWright wrote in post #5704995 (external link)
You're obviously not afraid to get crap on your lens or worst yet - damage it... :cool: Given that, what do you use to clean it???? I usually use a rocket blower, and then steam/breath with my microfibre towel to clean my UV (or CPF) filter.
iamaelephant
Jun 11, 2008 19:30 |  #10
Keep in mind that depending on the lens, stacking filters can also cause vignetting.
-- Martin
Canon 30D | Tamron 17-50mm f/2.8 | EF 50mm f/1.8 II
airfrogusmc
Gallery: 179 photos
Jun 11, 2008 19:36 |  #11
^^^^^Me neither.^^^^^
Double ­ Negative
*sniffles*
Jun 11, 2008 19:40 |  #12
So I take it you have no weathersealed lenses which Canon recommends fitting a UV filter to, to complete sealing? Or shoot in harsh environments?
That's cool. But I fit both scenarios. ;)
stuman16
Jun 11, 2008 21:34 |  #13
Hermeto wrote in post #5704746 (external link)
What?
I'm not trying to accomplish any effect by having both.
The UV is just there all the time for protection and I don't see the need to remove it and risk allowing dust onto it and the front of my lens when I use a CP filter.
I add the CP filter to get a bluer sky, reduce reflections and add contrast and it does that whether the UV filter is there or not.
WaltA
Gallery: 10 photos
Joined Feb 2006
Jun 12, 2008 09:44 |  #14
There are posts ad nauseum here in POTN about the pro- and anti- lens protector question. Its a Ford/Chevy question and usually ends up in everyone agreeing to disagree. Its a good thing we have personal choice and can do whatever we like.
My question to the OP is - since your main purpose in using the UV filter is for lens protection why don't you just use a clear glass one instead. Then you would avoid any possible chance that your image quality is being affected by the filter - cheap or expensive?
Clear glass and a lens hood seems to me to be a logical solution to cover all angles.
Walt
400D, 5D, 7D and a bag of stuff
Double ­ Negative
*sniffles*
Jun 12, 2008 09:48 |  #15
^ A UV filter effectively IS "clear glass." A skylight filter on the other hand, would be slightly warming. They do make some "digital protective filters" but I'm not sure what the story is with those.
2,337 views & 0 likes for this thread, 13 members have posted to it.
2693 guests, 163 members online
