Thread started 12 Jun 2008 (Thursday) 11:39
Exposure level indicater w/ Flash not correct...
DepthOfField
Jun 12, 2008 11:39 |  #1
I notice even with the 580EX II flash attached to my 40D and a 2.8 lens the exposure level indicater shows underexposure. When I do take the shot the images comes out perfect. So does the flash suppose to let the camera know that it will compensate for the low lighting and the meter would be showing perfect exposure?
3X Canon 5d Mark II | Canon 24-70mm f/2.8L | Canon 70-200mm f/2.8L IS | Canon ES 16-35mm f/2.8L | Sigma 105mm f/2.8 EX Macro | Canon 580EX II Speedlite x3
kdfederer
Jun 12, 2008 12:00 |  #2
That doesn't help when you're using as fill flash. With fill flash, you set perfect exposure and the fill flash helps the shadows.
The amount of underexposure (according to the meter) tells the flash how much flash is needed to get correct exposure.
Digital Rebel XT (350D) w/Opteka Grip - Canon 18-55 IS - Sigma 70-300 1:4-5.6 APO DG - Sigma EF-500 DG Super Flash
E-K
Jun 12, 2008 12:25 |  #3
The exposure level indicator in your camera measures ambient light only. The flash doesn't really know how it will impact the exposure until a pre-flash is fired or during the actual exposure (depending on the mode, etc...).
e-k
DepthOfField
Jun 13, 2008 05:36 |  #4
kdfederer wrote in post #5709292 (external link)
I'm not using it as fill but for low lighting conditions. In that case looks like I don't need to worry about what the sensor is show since the flash will compensate correct.
1,038 views & 0 likes for this thread, 3 members have posted to it.
2775 guests, 162 members online
