Thread started 13 Jun 2008 (Friday) 12:31
Canon Lens Hood Or One For $5.99?
DavidSR
Jun 13, 2008 12:31 |  #1
Well, as the topic states. I've seen the price for Canon's hoods and I'm not prepared to give them $30 for a hood. Wolf Camera sells a generic hood for $5.99 that screws onto where the filter goes. Will this prevent me in using a filter? Any cons. other than that?
Thanks guys!
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
beezwax
Jun 13, 2008 12:35 |  #2
you can never go wrong with Canon products compared to generic
i say get the canon
MYGEAR
GULFCOASTTUNDRAS.com (external link)
djeuch
Jun 13, 2008 12:37 |  #3
I always buy the Canon variety - it's expensive, but functionally excellent.
Canon 40D w/BG-E2N Battery Grip | Canon 5D w/BG-E4 Battery Grip | EF 70-200mm f/2.8L IS USM | EF 24-105mm f/4L IS USM | EF 85mm f/1.8 w/ET-65III | EF 50mm f/1.4 w/ES-71II | Canon 1.4x TC | Lowepro SlingShot 200 AW | B+W 77mm MRC (010) filter x2 | Speedlite 580EX II
alduin
Jun 13, 2008 12:39 |  #4
If the hood itself has threads that a filter can screw into or you can screw the filter onto the lens and then attach the hood to the filter, then no. Otherwise it will most definitely prevent you from using a filter.
I've got a hood for my 50mm that mounts on the filter threads and can't stand it. It's a real hassle to get on and off. If your lens is made for a bayonet mount hood, you'll quickly recoup the extra $20-some bucks in time spent shooting rather than messing with screwing the hood into the filter threads.
7D+BG-E7 | 5D | G9 | 24-70 f/2.8L | 70-200 f/2.8L IS | 100-400L IS | 10-22mm | 50mm f/1.4 | 580EX II | 430EX II | YN565EX
Manfrotto 055XPROB/488RC2 | 680B/234RC
SkipD
Joined Dec 2002
Jun 13, 2008 12:40 |  #5
DavidSR wrote in post #5715984 (external link)
If the OEM (Canon) hood mounts to an outer "bayonet" connection - especially if the hood mount "thread" is on the body of the lens rather than the moving part of a zoom lens - that is FAR superior to a hood that mounts to the filter threads.
A rigid hood is much better for crash protection than a cheapie folding rubber hood.
Canon's hoods probably do a far better job of blocking stray light sources from hitting the lens than any generic hood would.
Skip Douglas
DavidSR
Jun 13, 2008 12:44 |  #6
Ok, thanks guys! I guess I know what to get next :)
851 views & 0 likes for this thread, 5 members have posted to it.
2771 guests, 159 members online
