phili1 wrote:
Luminous landscapes rate Photokit no. one and someone on this forum rates Magic focus No one. And others swear by Fres Mirandas program best and I have both. I see very little difference between them. Photkit is my favorite over the others rigth now.
That's not what Michael Reichmann said.
He compared Focal Blade and Photokit Sharpener and concluded:
"The obvious question is — which one is better, PK Sharpener of FocalBlade? It isn't a cop-out for me to say that neither one is better than the other. They are both at the head of the class, though they are quite different in how they are used and what they demand from the user."
Then he said this:
"If you are want the most intensive hands-on control over every possible sharpening parameter, then FocalBlade is your preferred choice. If you'd rather have a somewhat simpler approach (though not at all simple), with equally impressive final results, then PK Sharpener is the way to go. For 90% of users PK Sharpener will provide the preferred workflow and is easier to use."
As one who has written his own actions that employ the same method as Photokit Sharpener and added features (and even had the folks at Photokit borrow a couple from me) *AND* who has used PK Sharpener and owns Focal Blade, I can assure you that Photokit Sharpener is not #1. Focal Blade gives you more control. For crafting the very best image, Focal Blade is superior to PK Sharpener, IMHO. If you are serious about image quality, you want control, not generic presets, IMHO.
People have a lot more choices than PK Sharpener and Fred Miranda's plug-in.
Cheers,
Mitch
