First shots with 40d upgraded from 20d. Looking to capture the emotion. C&C always welcomed...
82NoMe Goldmember More info | Jun 14, 2008 00:25 | #1 First shots with 40d upgraded from 20d. Looking to capture the emotion. C&C always welcomed... Cheers... jim
khall Goldmember 3,803 posts Joined Mar 2007 Location: Wollongong Australia. More info | Jun 14, 2008 04:45 | #2 Not really captured the sharpness yet or stopped the movement. YNWA.
1/1000 @ f7 should have stopped the motion and given you a sharper image. What setting did you have for the focus? Were you on One Shot, AI Focus or AI Servo? What AF points were you using? All of them or just the center? 7D,
vetkrazy Goldmember 1,019 posts Joined May 2006 Location: Just North of South, next to the Joshua tree More info | Jun 14, 2008 11:51 | #4 You need to get away from the "action program". You are letting the camera make the choices, kind of like a big point and shoot. At this level 1/1000 is not fast enough and no one would use f/7. Learn to use your manual mode or AV and you would see an improvement. Center point focus and AI Servo and open the lens wide. Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
Doublea17 Senior Member 420 posts Likes: 3 Joined Mar 2008 Location: Oregon More info | Jun 14, 2008 13:26 | #5 I started with 40D and shot fastpitch my fisttime with "action program" Like vetkrazy said learn AV or manual and your pictures will turn out better ____________
Thanks for the tips. Cheers... jim
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Jun 14, 2008 20:56 | #7 Yep, AV mode for me, f/2.8 - 3.2, AI Servo, center focus point.
Thanks Mike the above shots were taken w/ a Canon 17-85 in Action Mode. Cheers... jim
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Jun 14, 2008 21:13 | #9 The answer to your question is yes.
^ What determines the the ISO in lets say bright sunshine noon? Cheers... jim
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Jun 14, 2008 21:46 | #11 When I shoot in AV mode, I adjust the ISO as necessary (up or down) so the shutter speed will be fast enough to stop the motion.
Thanks Mike, I was reluctant to post these pictures based on the talent that post in this section, but I am sure glad I did for the members here have been very polite in educating me…Thanx Cheers... jim
manutd101 Goldmember 1,261 posts Likes: 1 Joined May 2008 Location: Southern NH More info |
Thanks for all your help. Tried again today in Manual mode. C&C welcomed. Cheers... jim
khall Goldmember 3,803 posts Joined Mar 2007 Location: Wollongong Australia. More info | Jun 15, 2008 23:42 | #15 Much better, but her face is still not pin sharp. YNWA.
| Latest registered member was a spammer, and banned as such! 2688 guests, 155 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
