Thread started 14 Jun 2008 (Saturday) 01:22
markin q3- torque dial
azpix
Jun 14, 2008 01:22 |  #1
Markins owners,
just got my q3. I'm not fully grasping the use of the torque dial. when and why are you adjusting it? does it just make the knob more or less sensitive.???
thanks.
Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
jhom
Jun 14, 2008 13:46 |  #2
azpix wrote in post #5719459 (external link)
Markins owners,
thanks.
You don't need to use it if you don't want to. However, it is one of the great features of the Markins. It allows you to set the sweet spot. In other words, once set it, you can easily reposition your gear without it flopping around as you do it. Just follow the instructions on setting it. Essentially, first loosen the dial. Then tighten the main knob so that your gear is stable and won't flop or change position. Then tighten the dial. Once set, you can loosen the main knob without worrying about your gear flopping. This comes in handy when you need to frequently reposition to frame your shot.
Jim
René ­ Damkot
Jun 14, 2008 13:47 |  #3
It simply puts an "end stop" to the big knob.
You set the minimum tension you want with the big knob, then turn in the dial, and you won't be able to open up the big knob further then that...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
1,146 views & 0 likes for this thread, 3 members have posted to it.
2771 guests, 159 members online
