Looking at getting a BG-E3 battery grip, but wanted to find out if I need to order more batteries (have 3). Does the battery grip drain one battery at a time, or does it drain both batteries concurrently? Thinking of my rotation scheme. Thanks!
NYC2SOCAL Member 207 posts Joined May 2008 More info | Jun 15, 2008 01:44 | #1 Looking at getting a BG-E3 battery grip, but wanted to find out if I need to order more batteries (have 3). Does the battery grip drain one battery at a time, or does it drain both batteries concurrently? Thinking of my rotation scheme. Thanks!
keegsmeister Senior Member 380 posts Joined Apr 2006 Location: Perth, Australia More info | Jun 15, 2008 05:20 | #3 dont think it operates the same as your normal AA battery where one drains out if plugged simultaneously together. I've just got a generic grip and it works great. Keegan.
Jun 15, 2008 10:47 | #4 gofer wrote in post #5724431 Both batteries are used simultaneously. Thanks! I guess I should visit SterlingTek again..
Magic_Puzzle Member 145 posts Joined Jan 2008 More info | Jun 18, 2008 20:33 | #5 No doubt about it, both batteries are discharging at the same time. You will never find yourself with one discharged battery and one fresh one (unless you start that way).
Ukuleleman Senior Member 580 posts Joined Oct 2006 Location: England More info | Jun 19, 2008 06:25 | #6 Just to clarify the point, both batteries are discharging at the same time, but your camera will work with a single battery loaded in the grip, ie, it doesn,t necessarily need two batteries to be installed There are no shortcuts to any place worth going to
Robf Senior Member 385 posts Likes: 1 Joined Jul 2007 Location: UK More info | Jun 19, 2008 07:17 | #7 bear in mind that 2 batteries gives you a much longer life, so it might just turn out that running 2, with one spare is all you need...when the 2 run out, slam in the 1, and charge the 2...will probably suffice.
| Latest registered member was a spammer, and banned as such! 2661 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
