My lens says 58 on in if I want a rubber hood or UV filter is that the size I need to get?
dlee58 Junior Member 22 posts Joined Jun 2008 Location: Wichita, Kansas More info | Jun 16, 2008 20:27 | #1 My lens says 58 on in if I want a rubber hood or UV filter is that the size I need to get? Canon XSi w/BG-E5 grip, EF-S 18-55mm f/3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, EF 50mm f/1.8 II, Manfrotto 679
LeeSC Senior Member 816 posts Joined Apr 2007 Location: Camden, South Carolina More info | Jun 16, 2008 20:29 | #2 Yes. And if you are talikng about your IS kit lens I know 58mm fits because I have one that I use filters on.
midnight_rider "Thrown under the bus." 5,413 posts Joined Apr 2008 Location: Yonder by the crick, Ga More info | If you are referring to your kit lens then it takes a 58mm filter. The only stupid questions are the ones that go unasked. Welcome to the forum. I never, Not once claimed to read your post...
| Latest registered member was a spammer, and banned as such! 2661 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
