OceanRider wrote:
What is the actually the name of such filter(s). I can't recreate the effect in Photoshop elopements. Any ideas?
There are some different types out there that give nice results.
"Softar" filters are very nice and come in 3 degrees of softness ie; Softar 1, Softar II, and Softar III. I own 1 and II and have only used them on my medium format camera, but they are excellent!
There is also Cokin, who makes many types of special effects filters. I used this system 15 years ago, but many still do. They have/had a holder that you screw into the lens as a filter that you slide a square plastic filter into. Pretty neat actually, and not as spendy. I have used the #1 and I liked it.
I have a set of Tiffen Soft FX filters that I intended to use but haven't. Saw samples and got a good deal on them at the time.
So, the last Ihave used is a homemade filter that I used for years... I bought an inexspensive plastic UV filter and put clear nail polish around the edge of the side that faces out, leaving a 2" or so spot clear in the center. I waited for the polish to get tacky and used my finger to gently press and swirl around the circle until all the "painted" area was smeared that way. I still left the center clear.
When it dried, I had a nice vignette that still showed the faces clear but the surrounding area diffused.
This was nice because unlike the old Vaseline coated filters, it dries hard and no lint or dust will adhere to it!! Of course, this didn't diffuse the entire scene evenly, but it's a nice effect.
Another one is the cross-screen filter. It is the one you use to turn a spot of light into a star. Using this without a spot of light will diffuse the scene a bit as well. But, not the best way to do it.
Have fun!
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams
1Ds MkII 24-70 2.8L, 70-200 2.8L, 100-400 4.5L, 100 Macro 2.8, 50 1.4
