Paul S wrote in post #5744725
Thanks for you feed back. Will change the metering setting. I had no way to check the histogram. It's was useless as I could not see anything on the display because of the sun. Tonight we will try again in AV
Pack- I should have gotten there a little earlier and talk to the UMP's. I think I will make a point of that from now on.
Dennis, I do have a Press Credentials. Would it be worth laminating the back with signed written permission from
the other parties ? AD - etc.?
Paul, it can't hurt, but if you find yourself in a situation where the umps are questioning who you are and why you're there, you're already on the defensive rather than being pro-active and asserting yourself like the pro you are. Like I said, regardless of whose permission you have prior to the event, at the moment of the game the umps (and even the host team's head coach at many HS fields) hold all the cards and they are the ones you need to convince of your legitimacy and right to be on the field.
In Illinois, photographers working HS games are required to be within a marked-off area that is determined by the host team's coach, and enforced by the umpires. When I shoot HS baseball, I carry a can of white spray paint with me to mark off this box which is usually against the fences along the base lines, and when the ground rules are discussed, this area is noted as being a dead-ball zone. I will approach the host team's coach before the game and introduce myself, state my purpose for being there, and ask him where he would like me to set up. I always wear my credentials around my neck and my EF 400 f.2.8L lens doesn't hurt my appearance of "knowing what I'm doing"
Not all umps require these boxes but they're supposed to, so by talking with them and the coach before the game, I demonstrate my respect for their authority and positions as well as showing my knowledge of the rules. Then, and only then, if they question why I need to be there, will I bring up having the approval of the AD, et al. BTW, having the approval of your PE will probably not mean much to the officials at the game. They are more concerned with safety of the players and others on the field, and the liability of the school in the unlikely event that something should go wrong. I also carry a copy of my $2 Million liability policy which frequently will have named the school as being covered.
