argyle wrote in post #5744697
1.) Hard to give an answer. The use of an ND filter is highly dependent on available light conditions at the time, and what your actually trying to do with it. That being said, since you already have a good polarizer, I'd recommend a 3-stop and 6-stop ND filter (round). Since the CPL will give you anywhere from 1-2 strops of reduction, it wouldn't make much sense to buy a 2-stop ND. You can use the two ND's and CPL in any combination to get anywhere from 1-11 stops of reduction. However, at wide angles, you will get vignetting when stacking. B+W (and I think Hoya) sell 10-stop ND filters as well. Personally, I prefer round ND's over the square filters...when stacking the square filters in a holder, there are too many paths for extraneous light to get in.
2.) I generally will use a GND filter in tandem with a polarizer (haven't tried it with an ND). When I do this, I forego the filter holder and handhold the GND filter in front of the CPL. See above response for round vs. square ND.
3.) Not sure I follow this question. If you have a slim CPL from B+W, then you don't have any front threads to attach another filter. You can always put a filter behind it (on the lens first), then have the CPL on the outside. This would at least make it easier for you to rotate the CPL since it'd be on the outside.
4.) Most people that go the IR filter route settle on the Hoya R72. They're not overly expensive, until you get to the 77mm filter size and larger. For some reason, 77mm seems to be the point at wich they become very expensive. You may get similar results as that of a converted body, but it'll be more difficult....you'll need a tripod, have longer exposure times, and any movement of foliage or clouds, even in the slightest breeze, will appear as OOF in the final image due to those long exposure times. Not to mention the high price of a 77mm R72 filter. IMO, best results are with a converted camera.
1. I have one Hoya ND filter and i want to use for slower shutter speed shots, not always CPL is the only filter recommended, but seems my ND [8x i think 3 stops maybe] is not slim enough, so that i am thinking to replace it [I mean buy another one better if so], i will use that ND with CPL or with another GND, so i know when use ND but which ND i should look at?
2. I don't like to handhold my filters, as i sometimes use shutter speed about 2-15 seconds, so any shake or movement will kill and waste my trials and time, so i prefer to use holder with release rather than hold that filter for more than 2 or 3 scnds.
3. I have that B+W with large frontal element, i didn't imagine i chose that one, i don't see any vignetting at ultra wide using this filter which is great, but as i said, with that frontal 95mm element i can't place any another filter on it even UV, here is a link to this filter, so check it and yu will know what i mean, so now do you recommend me to buy another slim CPL instead of that?
http://www.bhphotovideo.com …mm_Kaeseman_Circular.html
4. Ofcourse when sue all those lenses for slower shutter speed i must use tripod, so doesn't matter if i use slow shutter speed with any filter, tripod and release are must, so with IR filter i know i am going to use so sow shutter speed, and i am looking for that OOF moving clouds, and i will get some still shots even with longer shutter speed, houses cars and still objects don't move unless you move them, and i think that camera converted is better but i am not going to take that risk, i am not a big fan of IR so i think i will use just filter for a while for some shots, and i know they are expensive, doesn't matter as long i will buy one IR filter only.
