Thread started 19 Jun 2008 (Thursday) 07:49
Night soccer - what's required?
AdamC
Jun 19, 2008 07:49 |  #1
Hi all,
I've been shooting my son's soccer matches with my 400D + 70-200/4 for a little while now and reasonably happy with the results. Generally they're played midday-ish on a Saturday, so light isn't normally an issue - I usually shoot at 1/2000 or better at ISO 100. Last night however he had his first night game. I knew full well that my gear wasn't up to the challenge, but that wasn't going to stop me from having a go.
I found exactly what I expected - that my shutter speed was hopelessly slow, even at ISO 1600 - down to 1/5 - 1/10 or so. A fellow POTNer dropped by to say hello and kindly let me shoot for a while with his 300/2.8 - a lovely lens, but it clearly demonstrated that 2.8 still wasn't enough, as I was still only doing 1/50 - 1/100. In fact I whacked on the ol' nifty fifty as an experiment and found to my surprise that even F/1.8 wasn't enough on my body.
Yes yes, I know, the 400D is hardly the ideal sports shooter's tool. My goal is to "someday" upgrade to a 1D, but how much difference will it make to my ability to shoot fast shutter speeds in low light? Will ISO 3200 be enough? Or even 6400?
I include for your amusement the best of the worst from last night, mostly shot with the borrowed 300/2.8 (thanks Josh!) All required huge amounts of EC/fill/noise removal/etc in post.
[gallery (external link)|gear|flickr (external link)|blog (external link)]
Pete
Jun 19, 2008 07:54 |  #2
You can't really fight the laws of light sometimes, can you?
The alternative could be for you to allow some motion blur and get some movement into your shots in these conditions. Panning, blur, action. Look at is as an opportunity to stretch yourself artisically...
Pete
UK SE Catch of the Day
In2Photos
Jun 19, 2008 09:10 as a reply to  @ Pete's post |  #3
You could add a flash with a better beamer.
Current Gear and Feedback
Mark
Dammit I need sleep
Jun 19, 2008 10:26 |  #4
In2Photos wrote in post #5751816 (external link)
and a cp-e4
Mark
In2Photos
Jun 19, 2008 10:43 |  #5
pendulum15 wrote in post #5752268 (external link)
and a cp-e4
What if he doesn't add a Canon Flash? ;)
And yes, a battery pack would also be a good idea. :D
AdamC
Jun 19, 2008 22:14 as a reply to  @ In2Photos's post |  #6
I haven't made any enquiries, but I'd presume that flashes are a no-no at these games. I'm trying to work out if shooting available light is viable. Is it reasonable to think that ISO 6400 = 4x the light of ISO 1600, and therefore 4x the shutter speed? Or is it not as simple as that?
ryant35
Gallery: 16 photos
Jun 19, 2008 23:13 |  #7
The only lights I have shot under that I found reasonable for night photography even at f/2.8 are pro stadium lights.
5DMK4, 7DMK2, 24-104mm f/4 L, 70-200mm f/2.8 IS II, 100-400mm f/4.5-5.6 IS MK2, 17-40mm f/4, 100mm f/2.8 Macro, 35mm f/1.4,1.4X & 2X TC III 580EXII
www.ryantorresphotogra​phy.com (external link)Photography Facebook Fan Page (external link)
AdamC
Jun 19, 2008 23:49 |  #8
ryant35 wrote in post #5756700 (external link)
These definitely aren't up to that standard - it's just a small local soccer field.
KIPAX
Jun 20, 2008 04:16 |  #9
Night time football requires a fast lens. f2.8 is fast enough for your lighting. Just raise the iso as much as you can. really is that simple. If you where only getting 1/50 with a 2.8 at iso 3200 then it would have been too dark to play :)
Don't even consider flash.
In my tenth year as a Full time Sports Photographer.
living the dream at www.kipax.com (external link)
Mark
Dammit I need sleep
Jun 20, 2008 04:20 |  #10
KIPAX wrote in post #5757574 (external link)
Why do you say that, most of my sports are in the day, and I use a flash as fill (it actually works quite well)
When I shoot night sports I will use a flash if the lighting is too crap, but keep the ambient as fill
Mark
AdamC
Jun 20, 2008 04:23 |  #11
Thanks Kipax. F/2.8 was nowhere near enough (1/100 when I was lucky, which wasn't often, mostly 1/20 - 1/30) on my body, which only does ISO 1600. I happily acknowledge that the 400D isn't a sports body - I guess I was hoping to know whether 3200 or 6400 on a 1d would do the trick.
In2Photos
Jun 20, 2008 07:30 |  #12
AdamC wrote in post #5757585 (external link)
So why would you think that 1/80-1/120 would work? That is what you would get at f/2.8 and ISO 6400.
Why don't you ask about flash? There is no harm is asking!
KIPAX
Jun 20, 2008 07:36 |  #13
In2Photos wrote in post #5758062 (external link)
If the ground is so dark you cant get pictures at iso 1600/f2.8 then its pretty dark.. Your only going to be able to use flash at a reasonable close range.. these are kids..
So quite dark. bright flash at close range at kids playing football.. seriously you shouldnt be firing flash at them in those conditions.
In2Photos
Jun 20, 2008 07:44 |  #14
KIPAX wrote in post #5758086 (external link)
The 580 EX II GN is 190 feet at ISO 100. So at f/2.8 that equates to ~70 feet. Going from ISO 100 to ISO 1600 is a difference of 4x the guide number (4 stops). So now the effective flash range (at or below sync speed) is ~280 feet! Still don't think your flash will work? Add the Better Beamer and it gets even better.
Kids playing a sport won't notice a flash going off on the sidelines unless they are intentionally looking for it.
AdamC
Jun 20, 2008 07:55 |  #15
I don't.
Is it? Thanks. That's what I wanted to know.
You're right, there isn't, and I might. I just assumed that having someone flash a bright light at them would be distracting and annoying.
3,122 views & 0 likes for this thread, 8 members have posted to it.
2688 guests, 155 members online
