Thread started 19 Jun 2008 (Thursday) 19:35
Flash in a black room?
Aszental
Jun 19, 2008 19:35 |  #1
Hey, i was wondering what you guys do when your shooting an event and the entire room is black, the walls and the cealing.
The ambient light is also pretty dim, so a flash is necessary.
How do you get a nice looking flash when there is nothing to bounce from?
Website (external link)
hastur
Jun 19, 2008 20:52 |  #2
Check out http://super.nova.org/​DPR/Design/ (external link) . I don't mean to be short, but this guy explains more than I could.
Have Fun
Rob
How can you trust a man who wears both a belt and suspenders? The man can't even trust his own pants. - Frank (Henry Fonda) in Once Upon a Time in the West.
20D, 17-55, 35-70 f/3.5-4.5, 50 f1.8, 85 f/1.8, 430EX
Bob ­ D.
Jun 19, 2008 20:52 |  #3
You need to supply your own ceiling or wall to bounce from.
Make your own bounce card or buy one if you have money to burn.
Search on bounce card and you'll find all the help you need for this one.
photojournalista
Jun 19, 2008 20:56 |  #4
What I did was shoot direct flash sometimes with, sometimes without flash modifier. Sometimes stofen omnibounce, sometimes an index card.
photojournalista.blogs​pot.com (external link)
Nice painting, got photos?
steve547
Jun 19, 2008 21:47 |  #5
Aszental wrote in post #5755358 (external link)
Direct flash can be nice looking. I'd be more concerned about focusing in that environment.
Steve
_____
EOS 20D, EOS 5D MARK III,18-55mm kit lens, Canon 35mm/f2, Canon EF 24-105 f/4L IS USM, Canon 220EX, Sigma EF-500 DG ST, G2, Canon i960 photoprinter, Canon Pixma Pro 9000 printer, Tamron 17-50 f2.8 non vc.
photojournalista
Jun 19, 2008 22:43 |  #6
steve547 wrote in post #5756220 (external link)
Just turn on the focus assist beam on your flash and you're all set. ;)
vixeh
Jun 19, 2008 23:32 |  #7
hastur wrote in post #5755884 (external link)
Have Fun
Rob
This is some seriously good stuff! Thanks for the link. Like so many intimidating things, it's dreadfully simple after someone explains it properly.
5D | G9 | SD1000 | 16-35mm f/2.8 II | 24-105 f/4 IS | 70-200mm f/2.8 IS | 35mm f/1.4 | 100mm f/2.8 macro | 135mm f/2 | 580EX | 580EX II
Aszental
Jun 19, 2008 23:47 as a reply to  @ photojournalista's post |  #8
Ok well i went today whilst they were setting up to check it all out, here's what Im up against.
All ISO 1600
IMAGE: http://farm4.static.flickr.com/3120/2593898365_3b86fcbd84.jpg?v=0
F 2.8, 1/15
IMAGE: http://farm4.static.flickr.com/3261/2593899741_fe85aab14f.jpg?v=0
F 2.8 1/8
IMAGE: http://farm4.static.flickr.com/3032/2594739466_3d9bac4314.jpg?v=0
Thats what the roof looks like, pretty high up.
Ok one more quick question, in the event of rain im going to take a few portrait shots inside, the walls have this nice texture i can use as a background. The problem is, when i use direct flash there is a reflection that is really distracting
IMAGE: http://farm4.static.flickr.com/3293/2594740394_5ed5633960.jpg?v=0
What do you reccomend to take portraits on these walls? ( i can use an off camera flash)
Thanks for all the help guys!
Edit:
Oh when the curtains open up things get way better
IMAGE: http://farm4.static.flickr.com/3020/2594741710_65811f7540.jpg?v=0
F 3.2 1/320 (iso 1600 though, forgot to take it down)
Their just not sure if its going ot be open or closed, so i want to be prepared incase!
René ­ Damkot
Jun 20, 2008 07:22 |  #9
Black doesn't mean it will absorb all light, it just means it'll reflect a lot less then white...
You could still bounce the flash IMO (Have a look at this thread), but it will be terribly ineffective. A bounce card will probably work better...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
SkipD
Joined Dec 2002
Jun 20, 2008 07:46 |  #10
If you have a reflective surface behind your subjects for the portrait shots, the ONLY solution is to get your lighting source off of the camera. If the only light you have is a Speedlite (and you cannot afford to buy or rent something more appropriate), than you could have an assistant hold a LARGE (four by four feet, for example) bounce card above and to the left or right of you (and aimed at the correct angle). You would then turn your flash to aim it at the bounce card. That would then provide soft lighting that would not bounce directly back at your camera off the background.
Skip Douglas
tenoverthenose
Jun 20, 2008 09:58 as a reply to  @ SkipD's post |  #11
You can easily get by with direct flash. However, I would use off camera flashes in a room like that and then use the on camera flash as fill.
www.patrickpike.com (external link) | twitter (external link) | facebook (external link)
Dermit
Joined Nov 2005
Jun 20, 2008 10:04 |  #12
I shoot weddings and this is very typical reception hall type environment. I always shoot with one flash on camera/bracket (for fill) and one or two on lightstands off camera and usually into umbrellas for the off camera lights. Off camera main light will improve shots in rooms like this about 1,000% over one flash on camera. You will have to decide whether to shoot ETTL or manual. That will be determined by the gear you have and/or the type of shooting you will be doing, i.e. candid, posed, etc.
But, if they do open the curtains make sure and use that natural light to your advantage, especially at the tables close to the windows. This light can be way better than any flash will give you if used properly.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
Wilt
Jun 20, 2008 11:24 |  #13
Aszental wrote in post #5756869 (external link)
Shoot at an angle to the wall...'angle of incidence = angle of reflectance'
Aszental
Jun 21, 2008 04:12 as a reply to  @ Wilt's post |  #14
Thanks for all the responses guys
Do you think that one 580 EX II as master, and one 580 set as a slave off camera on a light stand would be the ideal way to light this event? Anyone her that done something like this before?
Dermit
Joined Nov 2005
Jun 21, 2008 10:05 |  #15
Aszental wrote in post #5763284 (external link)
It's exactly how I do it.
2,545 views & 0 likes for this thread, 12 members have posted to it.
2804 guests, 149 members online
