Thread started 20 Jun 2008 (Friday) 13:16
IR Test with new Photoshop steps
aram535
Jun 20, 2008 13:16 |  #1
I am testing out some new steps in photshop... would love to hear some CC.
Here is the original out of the camera (sharpen, watermark and reduce only):
Here is the post PP:
Now if anyone can figure out how to liven up the sky without cheating and removing the sky and putting in a new one I would be greatful.
Thanks.
P.S. If I could only get the clouds to stop moving I wouldn't have to worry about .... well anything.
Gear List * www.tranquilphotos.com (external link) * My Blog (external link)
luigis
Jun 20, 2008 13:33 |  #2
Hi Aram,
I do a lot of IR photography I hope I can help you.
What kind of filter did you use?
I think your pic might be a little overexposed.
The WB seems to be wrong, did you shoot in raw right? If so then white balance selecting the trees/foliage to be white. You might also try to invert the red and blue channels.
Luigi
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
joedlh
Gallery: 52 photos
Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea.
Jun 20, 2008 15:40 |  #3
I'm no IR expert, but they look to be about 2 stops overexposed to me.
Joe
Gear: Kodak Instamatic, Polaroid Swinger. Oh you meant gear now. :rolleyes:
http://photo.joedlh.ne​t (external link)
Editing ok
aram535
Jun 20, 2008 17:33 |  #4
luigis wrote in post #5759909 (external link)
Hi Aram,
Luigi
I am using a 58mm Hoya R72 0.75 pitch filter.
The EXIF should be in tact but here it is:
XTi
30.0 secs at f/5.6
28mm focal length (28-80mm f/3.5-5.6) (its the only semi-decent lens I have that is 58mm)
0 EV
ISO equiv 400
Manual exposure
RAW
I actually was doing the timing manually but none of mine were coming out the way I thought they should so I set the shutter to 30 seconds to see what would happen.
I am unsure on how to "flip" the channels. Can you clarify?
Thanks.
luigis
Jun 20, 2008 17:38 |  #5
I would start by trying to bring the exposure down from the RAW file, try 1 or 2 stops down, next time you will be able to calculate the exposure time better :)
Then correct the white balance manually the picture you posted has the color temperature too high for infrared.
Sometimes the result is good enough after correcting the exposure and WB, sometimes you want to invert the red and blue channels.
To swap the blue and redchannels from the channels tool in PS bring red to 0% and blue to 100% in the red output and red to 100% and blue to 0% in the blue output.
Luigi
aram535
Jun 20, 2008 21:14 as a reply to  @ luigis's post |  #6
Ok reduced exposure by -1 (3 stops). Swapped the Red and Blue, but now its way too blue.
Thank you very much for the directions.
aram535
Jun 21, 2008 12:01 as a reply to  @ aram535's post |  #7
New test image. Just to complicate things a little more for myself I added a polarization filter to the mix.
This is the post PP shot, with just a level change.
luigis
Jun 21, 2008 12:15 |  #8
I think it is still overexposed, the whites in the foliage are clipped.
The second one looks better. It will probably be better with a shorter exposure with less blur from movement.
One thing you can do is to configure the histogram to be RGB (default is luminance) and check the RGB histogram after you take the picture, when shooting IR the important thing is to check that the red channel is not overexposed/clipped. That can help you adjust the exposure properly. With some practice you will develop an IR meter on your eye and you will be able to say "17 seconds" from the scene and ambient light and get it right.
Cheiri
Jun 22, 2008 10:01 |  #9
I know this isn't critique, but the original reminds me of cotton candy... yum.
aram535
Jun 22, 2008 10:49 |  #10
luigis wrote in post #5764909 (external link)
Wow, I think this was only a 10 second exposure. I think I did a 7 seconds and it didn't capture much. Even this was too dark to me before I brought it into Photoshop. I must be over doing the levels. I'll try again.
836 views & 0 likes for this thread, 4 members have posted to it.
2774 guests, 160 members online
