Thread started 21 Jun 2008 (Saturday) 09:33
The Alien Bees Foldable Softbox… a small non-technical review.
Piano ­ Man
Jun 21, 2008 09:33 |  #1
I wish to share my experience because prior to buying my lighting system I did a little research and I found many good things written about the actual Alien Bees lights but many negative reviews about the Alien Bees accessories. Again, my thoughts are non-technical and are just thoughts, not tested in any way. I am not a full time photographer, just a regular guy who has taken a couple of basic courses in photography many, many, many years ago in college and enjoyed photography for many years. I am now entering a new stage of photography using multiple strobes. I don’t work for any photographic related company. With that said, take everything with a grain salt.
The shipping box is a long square box. A black nylon bag with a cord around the opening is provided. Once the softbox is removed from the nylon bag, it starts to expand. The softbox shell is already fitted and the frame is already attached to the speed ring. With the speed ring positioned on the floor, the softbox basically falls into place. A small round piece of metal is attached to the support arms and sits in the center. Pushing this round metal piece down to a connecting metal post, which is connected to the speed ring, will expand the box to its’ full size. Once the round metal piece on the metal post, it is locked by securing a knob screw, very easy. An internal baffle is provided and again, it is very easy to attach with just four snaps. That leaves the diffusion panel. This is lined with Velcro, as is the softbox. This fits perfect and attaches very easily. I had my light tilted up and the fit onto the light was smooth, quick and easy. Breaking it down seems to be even easier. Again, this is non-technical so I can’t provide any data regarding impact of the internal baffle.
After opening the package and setting this up in what seemed like a minute but was probably three, I must say that this is SO easy to use. My experience with softboxes is very limited. I have a friend that has let me borrow his equipment and I used his softbox only once because it was a royal pain to put together. The Alienbee Foldable Softbox 32 x 40 is as easy as one, two, three. Please note that this is the FOLDABLE softbox, they also sell a standard softbox which I have read is a little more involved. The foldable was twenty bucks more and I think well worth it. Overall, it feels solid when put together. Hope to post some results in the near future.
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9447.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9505.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9499.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9492.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9486.jpg
Curtis ­ N
Master Flasher
Jun 21, 2008 11:23 |  #2
Thanks for sharing! I always wondered how those things worked.
I have always used umbrellas since all my shooting is done on location, but I might give one of these a try.
crazyskillz07
"invisible to everyone"
Jun 21, 2008 11:38 |  #3
I am seriously considering one of these.
-Turk- Blog (external link)
Canon EOS 40D w/ BG-E2N... Canon EOS 30D...
amonline
Jun 21, 2008 14:45 |  #4
How much light do these eat up?
TMR ­ Design
Joined Feb 2006
Jun 21, 2008 17:12 as a reply to  @ amonline's post |  #5
I would imagine it's no more than any other softbox, depending on the thickness and density of the diffusion material used, and whether you have the internal baffle installed, no more than 1 stop and probably less.
Robert
pepperoni
Jun 21, 2008 19:02 |  #6
Yes, these are very easy to work with. I have the large foldable octa and it's ready to go almost instantly. The standard softboxes take a bit more effort.
My $.02
Mamiya. Canon. Elinchrom.
Piano ­ Man
Jun 21, 2008 20:05 as a reply to  @ pepperoni's post |  #7
I have been asked about the bottom side of the speedring and the assembly.
On the outer side of the softbox, near the speedring the black material has four cuts, approximately two inches long that have Velcro on each side. There are four turn knobs on the outer side of the speedring. I can only assume that removing these turn knobs and the four screws that are visible on the other side will cause the speedring assembly to come apart. But as stated earlier, it arrived fully assembled.
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9510.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9511.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9516.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9517.jpg
FlashZebra
This space available
Jun 21, 2008 20:23 |  #8
These devices are really nice.
The only thing that I do not like about them is that when they fold up, they are not as nearly as compact as a traditional softbox broken down.
But, the ease of setup is great.
Enjoy! Lon
tetrode
I am a walking repository of thoroughly useless information
Jun 21, 2008 20:31 |  #9
FlashZebra wrote in post #5766896 (external link)
The only thing that I do not like about them is that when they fold up, they are not as compact as a traditional softbox broken down.
Enjoy! Lon
You're absolutely right about that, Lon. I have two folding SP Studio Systems boxes (soft and octa) that are built along the same lines as the Alien Bees modifers. Assembly/disassembly is a snap but, because of the fixed speedring, they're both fairly bulky when packed.
Dave F.
FlashZebra
Jun 21, 2008 20:35 |  #10
Curtis N wrote in post #5764684 (external link)
Then you may be right at home with these folding softboxes, as from my view they are built with umbrella technology as the underlying theme.
Enjoy! Lon
Piano ­ Man
Jun 28, 2008 14:14 as a reply to  @ FlashZebra's post |  #11
Requested pics - sorry it took so long, It's been a VERY busy week!
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9489.jpg
IMAGE: http://img.photobucket.com/albums/v732/Keithcpd/Softbox/IMG_9451.jpg
Mike-DT6
Aug 18, 2009 04:16 |  #12
Excellent article, thanks! I just found this thread via Google whilst trying to look up how the folding mechanism works.
The information in the Alien Bees PDF file for these folding soft boxes left me none the wiser!
Mike
Gear list
9,164 views & 0 likes for this thread, 9 members have posted to it.
1332 guests, 139 members online
