I did a search and the closest I could come to an answer was here:
https://photography-on-the.net …=487523&highlight=skyport
I'm about to get extra receivers from B&H (US).
From the above thread, it seems that there should not be any difference in frequencies, but when I check on my existing set, there is a very clear 'CE' marked on the back of everything.
IIRC, that 'CE' denotes frequencies for Europe and Asia???
There is a statement in the manual which states:
CE This device has been tested and found to comply with the requirements set up in council directive on the approximation of the law of member states relating to EMC Directive 89/336/EEC, Low Voltage Directive 73/23/EEC and R&TTE Directive 99/5/EC
In the manual for the receiver, the listed range of frequencies are:
Default with all 3 slider switches 'OFF' - Trigger Freq 2456/Mhz and Remote Freq 2448/Mhz
With all 3 slider switched 'ON' - Trigger Freq 22475/Mhz and Remote Freq 2467/Mhz
My question: Can I use Skyport Receivers bought in the US with my Asia bought Skyport set with the 'CE' designation?
Thanks in advance.
